It looks much better than with empty optics. Will it be available in your store?
And what will be the price for spacer for C8?
I will offer 6x ANNA within C8 DIY kits for now, I have limited number of them. Price of spacer is yet to be determined, I will have first batch this week.
The LD-B4HV. Can someone tell me what the different connection points in this image are: Capture hosted at ImgBB — ImgBB
+ battery power is on the back side
- battery power is on the edge (I)
A is + LED, B is - LED and C is gate?
This driver should turn on when connected to power (without switch) ?
The last page of this PDF has what you need:
Ok, wasn’t sure since that is not exactly the same driver.
But then I guess my A is A in the datasheet (LED +). My B is S in the datasheet (LED - ). My C is G in the datasheet (gate) like I thought.
Thank you!
I glanced at your picture but there are indeed a few differences mentioned on the product page as well. Maybe it’s best to wait for LED4Power to confirm.
Buoyen, I sent you answer over email.
Works:D
Thank you both!
Hi Neven, can you already estimate when the new e-switch driver for Convoy C8F 21700 will be ready for sale?
Best regards, Thomas
Hm, I didn't mention any e-switch driver for C8F? Do you mean subZero FET switch for C8 (which uses e-switch)?
When will the following things be available:
- 30A driver
- Luxeon MZ LEDs on PCB
- FET switch
MZ leds - next week 100%
-18,24,30Amp drivers, FET switch,spacers - next week 95%
What driver do you recommend for C8, 1x Luxeon MZ, Fet switch?
Depends on what you want, max. output light, or light for general use, so max. current can be anywhere from 3Amp to 15Amps. 12Amps looks like sweet spot for hot rods.
C8TT head build with CUTE-4-SS optics,4x Luxeon V 4000K, 24Amp LD-B4 driver and subZero FET switch:
https://budgetlightforum.com/t/-/37376/5756
Sorry if I mixed something up here. I assumed there is a LD4 driver planned with e-switch firmware on it to work with the C8F.
I asked some months ago here: https://budgetlightforum.com/t/-/46929/418
I remember someone asked, well good news is that I will finally start with driver design upgrade and new firmware .This will take some time,but I think it will be worthy.
Thank you Neven! That's good news indeed. :)
Cheers, Thomas
Luxeon MZ 5700K 90CRI (9080 Nichia rating) are finally here, flux bin is R!
Maukka tested MZ LED from Mouser before, it seems Mouser's reel is either high P bin,or low Q bin.
1 bin up from the koef3 test. :+1:
