Both good points Zulumoose.
Which is why I felt it important to state my test conditions.
The first test has now run to completion. I got a further 55 mins or so on MAX CW and the tube and cell were still not “hot”. I’m topping off a protected Panny 3400 at the moment for another test.
Typically I have been using the lantern attached to a metal surface. I chose to let it hang so the magnetic cap could not use the metal as an additional heatsink.
Your idea of sitting it on an insulating surface might have to be part of my further testing but I’ll wait until I get my IR gun back again after the weekend.
Checking using a steel ruler, it appears the tailcap and the plastic base are exactly flush when screwed down tight. You could always back the cap out a little if it wasn’t, as the threads are not anodized. So yes, the magnetic tailcap does physically touch the surface.
Having said that, I suspect that the amount of heat drawn out through a few threads and layer of paint over a circular contact surface only 20mm (3/4”) in diameter would be pretty minimal.
I just wanted to rule that possibility out for my tests.
We humans feel pain at 55 degrees Celsius, and experience that as alarmingly hot. Electronics can withstand 250 degrees Celsius and more. Li-ion batteries are in between, thermal runaway starts only at over 150 degrees Celsius, but I guess degradations of the battery already starts at lower temperature. But still I reckon that a battery at 80 degrees Celsius (way too hot too touch) would not be unsafe? Anyone with more knowledge about that?
Btw, thanks for the very good hands-on review Den!
HKJ frequently ends his tests with temperatures well over 50 Celsius degrees over ambient. Maybe the cell vented because it was somehow faulty?
ADDED:
Mooch frequently exceeds 80 degrees. Sometimes 90.
Quick browse and I found him going to 97:
All the HKJ reviews I’ve read he usually ends the amp draw tests early if they exceed 80°C. For a continous discharge rating it has to stay under that temp.
In those tests the battery chemistry is generating the heat, not it being heated by an external source. Maybe that’s an important distinction?
A member of the German TLF just checked his Zanflare T1 with the original batteries. He also used an IR thermometer. These are the results:
Discharge start @ 4.12V, maximum brightness in coldwhite:
o IR-temp. on tailcap: 0:00h 25°C, 0:15h 41°C, 0:30h 48°C, 0:45h 51°C, 1:00h 51°C
o IR-temp. after 1:00h on battery inner tube, max. 10s after interruption of operation / removal of battery: 53°C, 3.7V resting voltage
Test means nothing if we do not know the conditions of the test.
Ambient temp?
Airflow?
Orientation of lamp?
Material in contact with tailcap?
Ideally the test should be done without airflow at a known ambient temp in worst case scenario of lamp standing upright on an insulating surface like wood, or even worse on material, such as a tablecloth, blanket etc.
I doubt a cell vents below 90°C internal temperature. The internal temperature will depend on current draw and internal resistance in the battery (And of course ambient temperature). This means that the risk of a venting cell will be high when using a cell with a current draw that makes it hot when the tube also is warmed from the led.
I wonder how much the led heats up the interior of the battery tube at the top, leds can run above 100°C (The temperature of the tube may not tell the full story).
After 10 days of daily usage of my three T1s, today, just before I read your post, my daughter bring me her T1 so I can recharge it and for the first time I noticed the very hot tail cap. Hasn’t happened until today even after hours on max so my guess - and its only a guess - maybe not all T1s have that issue?
I will keep my eyes open about this dangerous behavior.
Just thinking out loud here… and getting strange looks from people around me.
Know the Nitefox UW360 flex-neck light-thingy? It comes with a magnetic-suck base (seriously!) and a ferric disk to act as a wider stabilising base, and to be able to stick it semi-permanently to another surface.
Well, what about something similar, a ferric disk that would stick to the magnetic-cap of the T1, and with a wider base and thus more surface area, wick away heat to the outside world?
I have 3 T1s …… I ran all 3 for several hours on high CW and the tailcaps on all remained as cool as the ‘outside’ of my fridge…… Not saying this couldn’t change in the future but if there is a heat problem then it seems it may be a QC problem and would not be occurring in ALL T1s.
Considering the majority of present owners of the T1 are not experiencing the same thing as the op while using the cell that came with the unit but from a known old cell (might’ve already high IR) , shouldn’t it be fair to Zanflare to have this thread’s title edited ?
In my case it was a used older cell that overheated & began to gas fumes due to the battery tube being hot from the LED that are attached to it inside. It may not happen to all 18650 cells, but its still a potential risk with a weak, older, cheaper, or damaged cell in the lantern. When it comes to lanterns in particular, i focus on all safety concerns and potential hazards. unlike flashlights, lanterns will more likely be left unattended for long periods of time running in a tent or house, resting on or near flammable material. (even when people are asleep) and even if just one out of 500 of them that has a bad cell it it that causes its battery to gas or go full-vent due to the heat and catch fire is a concern.
No doubt that most who have this lantern may never have a problem, but the risk is there because of the flaw in that design using the same battery tube metal as the LEDs direct heatsink. My personal feelings on this lantern is that Zanflare should either reduce the maximum mode amp load, or re-design the LEDs to be on a separate sleeve with an air-gap from them to the battery tube. ( but neither is likely as they woudl probably discontinue it and offer a new re-designed model.
