Ok, thank you for clarification. Corrected the description.
I know that. What I was saying is that those reflectors are made to the same specs. I have no way to verify if they are made in same factory or not. I believe some parts can be sourced using common supply chain. And yes - I know this reflector was designed and produced specifically for BLF GT and is not some standard off the shelf product. It would still be more reasonable to just order(if possible) from company already equipped with appropriate tool chain than to build your own production line.
The reflector in the MF04 is bigger than in the GT. So they don’t have the same specs. Astrolux want to “one up” Lumintop by using a bigger reflector.
The GT reflector production is quite slow.
Astrolux had no choice but to go to a different reflector company if they want to crank out a bunch of MF04 lights.
Micmania: Gofer:This price isn’t right for people who bought MF04 in presale.
+1
hard to see … indeed :cry:
I think banggood realise other countries have new tax for importing or buying overseas and the sale number have dropped.
Australia now have gst tax and I’m slowing down the ourchasing.
The other mob are still GST free
Astrolux S42 4xNichia 219C/XP-G2/XP-G3 A6 2023LM Rechargeable Mini LED Flashlight
It’s now in direct promotion for 25.99 (-$13.96) until September 6th.
For use with high current 18650 cells to achieve full light potential additional 18650 body tube is available here: Astrolux S41/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $3.29 or with BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$2.80 |
$2.76 |
$2.73 |
$2.70 |
$2.63 |
Coupon code with nice discount is available.
» Request via PM here«
- 8 independent slots up to 1.5A current
- Li-ion (4.2V and 4.35V), LiFePO4, Ni-Mh, Ni-Cd supported
- support low capacity cells (min charging current is 100mA)
- manual individual current setting (0.1 - 1.5A)
- voltage display (to 0.01V)
- capacity measurement
- internal resistance measurement
- supports 21700 and 26650 without adapters
Excellent (as always) review by HKJ here:
Test/review of Miboxer C8 Smart charger
PALIGHT GS900 XP-L AT 900Lumens 2Modes Brightness Portable Searching LED Flashlight 18650/22650
- Cree XHP35 LED
- 1800lm max
- 10lm low - max runtime 170h
- max beam range: 250m (820ft)
- dual switch (side switch + tactical tail switch)
- USB rechargeable
- intelligent temperature protection system (ITS)
- battery indicator LED (in side switch)
- 3600mAh Li-Ion 18650 battery included
- holster included
great prices just placed the order for a GT Mini.
thankyou
thankyou
You’re welcome I’m glad you like it
- Cree XP-L HD
- uniqe retractable diffuser design
- max 1000lm
- min 1lm (900h runtime)
- 18650 powered
- magnetic base
- tailstand ability
- constant current driver
ThorFire TD26 XP-L 5Modes 1000LM Diving Under Water LED Flashlight 100M 18650 Suit Set
Coupon code with very nice discount is available.
NiteFox K1 XP-G2 60Lumens Single Mode Outdoor Portable EDC LED Flashlight Keychain Light AAA
Acebeam K65 XHP70.2 6200Lumens 8Modes Ultra-Long Range Brightness LED Flashlight
2pcs KeepPower P1835J 18650 3500mAh 3.7V Rechargeable Battery
Use coupon code 8D9793 to get $17.21 price (18% OFF).
These are supposedly Sanyo NCR18650GA with added protection circuit.
Nicron B60 XP-L HD V5 1000Lumens 6Modes Dimming Micro-USB Rechargeable LED Flashlight
- dual LED head: white Cree XP-G2 S2 + 395nm UV power LED
- 90° rotating head
- USB rechargeable (standard micro USB port)
- lighted side switch
- magnetic tail
Haikelite MT09R 3x XHP35 HI 6500LM MODE SET Super Long Range Momentary Searching LED Flashlight
XTAR PB2 Rapid Smart Phone Power Bank & Hidden LCD Display 18650 Battery Charger 2Slots USB Cable
It’s now in direct promo for $8.99 ($16.39)
Offer expires in 1 day and 19 hours (Sept 7th).
Best price to date!
This is a very compact li-ion charger/powerbank with two 18650 slots, magnetic cover and battery charge state display (description states LCD but looks more like standard blue 7-segment LED display).
Claimed conversion efficiency of up to 92%.
I’m seeing the XTAR PB2 on sale for $12, not $8.99. Still a decent price, but $8.99 would have been a steal.
edit: Weird… it shows $8.99 when just browsing the flashlight category, and when the page initially loads, it shows $8.99. But then it switches to $12 after a second or two.
