I have been called a wizard before :laughing:
Hmmm, I’ve got enough Scottish ancestry to be able to wear a kilt, need to get me one and see if it influences my creative juices…
Nice work, again, always enjoy seeing what you’re up to and it’s always a surprise. lol
Thanks. The creative juices aren’t in the kilt, it’s in the haggis.
Your bypass soldering looks great to me. I wouldn’t have the guts to have tried what you did on an already awesome flashlight.
Generation 0 Sinner custom hosts switch went bad a few years ago. The 10A Judco is no longer available (highest latchng switch rating they make now is 5A @ 14v and the base is physically larger). After conversing with Sulman as well as parts suppliers I knew what had to be done…
5A Judco modified to have a 20x20mm square base. Black delrin ring is just spring support, not a PCB. It looks rickety but this is actually as-designed originally (switch fits&functions as Sulmans original 10A did)
We can rebuilt him, make his brighter, stronger, throwier.
I’m excited, the light broke ~2015/2016!
For a bad switch in the Sinner, I just flip the retaining rings around and use a standard mini Omten board with spring. (plastic retaining ring to press the boot, brass ring up top to carry ground.) Very simple, might need to open the hole in the brass ring a bit for spring clearance but overall this is the easiest way to upgrade the switch in a Sinner.
Convoy C8 with C8TT head, CUTE-4-SS optics,4x Luxeon V 4000K, 24Amp LD-B4 driver and subZero FET switch:
Ceiling bounce lux shows similar numbers to C8 with anna optics and 6x LH351D 90CRI, so it should be around 6000-6500lm,battery cell was VTC5A.
Tint is great, no green,beam is very smooth without coronas, only SS bezel creates some artifacts.
Despite the large fins, head still heats up very quickly because of large power (~100Watts with fresh battery).
But it cools down considerably faster than C8 with alu spacer and similar total weight.
I'm sure at more sane power levels (~10Amps) this head would be more beneficial, 100Watts is just too much for this size (except for short bursts) without active cooling.
With battery voltage of 3.8V (nearly 50% discharged) current on high was still pretty good, around 19Amps, thanks to the very low Vf of Luxeon V.
More info about head:
https://budgetlightforum.com/t/-/38581
https://budgetlightforum.com/t/-/50427
There never was any retaining ring or anything. So apparently this was one of the first hosts that he built and it doesn’t use a retaining ring on the tail, only the physical stem of the switch held it in. When I first had the issue and spoke with him he said if this would have been a slightly newer, as he calls them “first generation body” that it would have been no problem to send me parts to convert it to a standard setup (mini Omten) or w/e I needed but because this was one of the first ones he ever made and it was so different that he couldn’t offer me anything except superseded part numbers.
Its not gonna be a super hot rod or anything so I expect this Judco to hold up better than the original.
His very first ones had a brass end piece that had a plastic retaining ring holding the switch in. One piece body with a brass bezel holding the lens onto the reflector. At any rate, glad to see you got it working.
2x LH351D’s, 1x 365nm UV
Have you considered sealing that with silicone?
Sealing what? The optic/reflector is behind an AR glass lens so it’s not open to air.
AR coated lenses block UV light, effectively killing the output of the UV emitter.
This is what I got:
LCWCQAR.CC MR-6L-L2
If that tells you something.
I like the color but it is a bit too warm for me.
The partnr tells it is first generation Oslon Square (they are at gen4 now), but your pics show gen2: gen1 was least efficient but with the best tints that Osram ever made, with gen2 the tint already was a bit greenish, but I never found the 96CRI version (I think).
Yes. In the X6 triple it draws more than 11A and puts out about 2100 lumens.
2100 lumen of ultrahigh CRI =
I finished a light I started a few weeks ago I’ve dubbed ‘The Frankenquad’
It’s a Thorfire C8s host (last version, with the aluminum pill). I installed a driver I built using Lexel’s 17mm TA driver PCB design I ordered from Oshpark. I used an oddball 20mm DTP MCPCB with four WW XP-G2, arranged in a 2x2 array (4p/3v electrical configuration), I got on Aliexpress and connected them up with 18 AWG silicone wire. Driver and tailspring got 20AWG bypasses.
Not surprisingly, the beam had a big dark spot in the center, so I tried reaming out an OP reflector. That helped, but not enough, so I applied to DCFix. That did the job, nice clean ( & very floody) beam. I tried the original reflector and the beam was still nice and clean, so I left it in place.
When tested with a UT210-E clamp meter, it pulled about 11A from a fully charged LG HG2. Not bad, but I wasn’t happy with it.
So, today, I reflowed some 90CRI LH351D emitters to another one of the oddball MCPCBs. I used 2x 4000K and 2x 5000k, mainly to avoid depleting stock of either emitter too much. New test results: ~17A peak with LG HG2 or Samsung 30Q, >18A with a Sony VTC5A; lots of nice high CRI light (and plenty of heat).
I think that’ll do. More on my blog. No beamshots yet, though. I have to redo them now that the new/final emitters are in place.
Another triple LED Novatac, this time with Noctigon and Carclo optic.
Sorry no WIP pictures.
Left, my old Novatac using triple Nichias & optic from KD.
Right, my friend’s Novatac using triple Nichias on Noctigon and Carclo from Intl Outdoor.
Also got my GT mini yesterday, modified it today… Samsung LH351D 5000K 80CRI emitter, domed, on the stock DTP 20mm copper MCPCB. Flashed Anduril to the driver, replaced the FET with an SIR800DP and put 18ga wires on it. 18ga spring bypass on the driver. Removed the pcb in the tail cap and fitted a copper disc with the large spring that came with the light, 20 ga bypass inside the spring.
The GT Mini came up recently so I added an Anduril build target for it. It’s the same as the D1S build, but with button LED support. In case that’s of interest to anyone. It’ll get updated periodically along with the other supported targets.
