It works in tandem with the cabin pre-heating feature, and can be activated with the app prior to departure. These newfangled cars!
Suffice it to say, the engineers aren’t oblivious to cold conditions.
A lot can also be said about the company, and how it operates, etc., but Tesla’s battery engineering is first-rate and it is considered a leader. That might change when the other OEMs come online and demonstrate their prowess, but I suspect it will still be competitive at least, with the head start it has gained in battery and charging infrastructure.
I like Tesla, but I don’t think they’re going to survive once other “real” car manufacturers catch up. Musk hasn’t met a production target on the new model yet. He’s not going to be able to compete against other companies that can pump out millions of cars, when he can pump out only thousands.
I’d like to see other companies purchase Tesla’s battery tech.
i actually like the lg for some reason. it’s the one i have the most of, recommended to me the most. and failed the least. that being said, i vote for the vt6a!
In general Sanyo/Panasonic, Sony, Samsung, LG ratings are closer to spec but often times they are overrated and do not reflect real world usage scenarios, therefore it is in a way BS. It’s the same as the lights from reputable brands such as Acebeam, Olight, Fenix, etc. measure 0-15% less than their specified output.
That’s why we need HKJ and Mooch tests to know how batteries perform in the real world. Also user tests are helpful too to confirm manufacturer’s ratings. Many batteries tested on my Xtar VP4 Dragon Plus reveal less than advertised capacities, with some exceptions like the Sony VTC6 that measures practically spot on or a bit higher than rating and Shockli 26650s that measure a good margin higher than the specified rating.
I wouldn’t get it. All 3600mAh cells do achieve their ratings. However, since their internal resistance is higher than 3500mAh cells, they have less real world capacity than their lower capacity counterparts.
I have a bunch of 3500mah GAs and VTC6 already that have higher capacity than the 30Qs and VTC6 performs better too. But I want the highest capacity for my ROT66 with the 219B because I’m planning to use it as a work lamp to make use of that gorgeous tint.
It does depend on how your going to use your ROT66. Most folks are wanting high output and not going to let the batteries run down below 3.6v or 3.7v so a high drain like the 30Q makes more sense.
In your case, you seem to be willing to sacrifice some of the high output in exchange for more run time at lower levels all the way down to lvp.
So in your case, the high capacity cells do make sense.
The cells you currently have should be fine. You won’t see a difference between 3500mah and 3600mah. The 36G may end up exactly the same as the GA.
Should you buy an untested cell like the 36G? Maybe, it’s Samsung so it should be quality. You can be the guinea pig and tell us how good they are and their measured capacity. Lol
The samsung 35E has the highest mAh of any current cell, and since their naming seems to be consistent I wouldn’t be surprised to see a “36” have slightly more capacity than the “35”
However I haven’t seen any tests of it or any places to buy some, where have you seen it?
I can’t find any info directly from samsung though.
As long as it’s official I think it would probably be better than the 35E.
I would personally wait for an HKJ review.
Im thinking the 36g is the 18650 version of the 48g. The 36g is rated at 10A continuous whereas the 35e is rated at 8A. The 36G is currently on sale in that link which is why I want to buy it. It’s cheaper than the NCR18650GA and on paper has a tiny bit more capacit
There are alot of cells that HKJ skips. I think he only tests cells available in the UK. He haven’t even tested the VTC5D and that’s a pretty popular cell around here for the max lumen guys.
I ordered the 36G to test. Will test them and post back.
The 36g is listed as well on IMRBatteries and QueenBatteries (China) as a 10A battery. The LG M36, also rated as 10A, isn’t really worse than the Sanyo 18650GA on HKJ tests, just not better.
Its all about the current draw. Depends a lot on what your referring to real world. To Dale its 15 or more amps. To a EDC person its 1 to 3 amps.
So which battery performs best depends on what current you subject it to. High drain less capacity, more current. Low drain high capacity, more capacity. All the datasheets I have seen list the capacity at a very low current draw, from what I have tested at low currents they do make their ratings. But if you are talking about their max current draw ratings, Yeah there’s really not many that will do what the rated current draw is safely.
Personally, I have 4 units of Samsung INR18650-36G that I finished testing the day before yesterday, they are continuous 10A cells, it is a little better than the LG M36, but the best of four that I I have tested has not exceeded 3552mAh in continuous discharge at 0.2A, accurate 4.20v at 2.50v accurate (discharge current cutout set to 0.01A is 10mA, so I can not get better than that), concretely this cell does not reach the 3600mAh as its rated capacity indicates, but it does not really surprise me, because I tested 10 units of LG M36 a few months ago, it has the same indication of nominal capacity is 3600mAh, and the best M36 of the lot did not exceed 3543mAh too. The only things that can be credited to these two new cells (Samsung 36G and LG M36) is better internal resistance than any other high capacity cell that existed before (Sanyo GA, LG MJ1 and Samsung 35E) and better voltage performance than previously equivalent discharge compared to older models too. Otherwise, but it remains to be confirmed in time, the M36 and 36G have supposedly a longer life, that’s all that knows about these two new cells.
They actually have lower internal resistance than the 3500mAh cells? That is surprising. Guess LG’s and Samsung’s cells are on a different level than the NCR18650G.
I was not talking about NCR18650G for comparison, but Sanyo NCR18650GA, LG MJ1 and Samsung INR18650-35E exactly.
The Pansonic NCR18650G, I would not even want if they gave me, they are more than obsolete cells, for that besides they are no longer manufactured and very hard to find new, for me they have their places only in a museum. The GA explode far G, if you buy a good rank of a good batch, it is true every time.
