He linked to the store selling it.
Here
I can’t find any info directly from samsung though.
As long as it’s official I think it would probably be better than the 35E.
I would personally wait for an HKJ review.
Im thinking the 36g is the 18650 version of the 48g. The 36g is rated at 10A continuous whereas the 35e is rated at 8A. The 36G is currently on sale in that link which is why I want to buy it. It’s cheaper than the NCR18650GA and on paper has a tiny bit more capacit
There are alot of cells that HKJ skips. I think he only tests cells available in the UK. He haven’t even tested the VTC5D and that’s a pretty popular cell around here for the max lumen guys.
I ordered the 36G to test. Will test them and post back.
The 36g is listed as well on IMRBatteries and QueenBatteries (China) as a 10A battery. The LG M36, also rated as 10A, isn’t really worse than the Sanyo 18650GA on HKJ tests, just not better.
Its all about the current draw. Depends a lot on what your referring to real world. To Dale its 15 or more amps. To a EDC person its 1 to 3 amps.
So which battery performs best depends on what current you subject it to. High drain less capacity, more current. Low drain high capacity, more capacity. All the datasheets I have seen list the capacity at a very low current draw, from what I have tested at low currents they do make their ratings. But if you are talking about their max current draw ratings, Yeah there’s really not many that will do what the rated current draw is safely.
Sweet, thanks.
If my guess is right it will have both better mAh and better current than the 35E, and that would be sweet
Personally, I have 4 units of Samsung INR18650-36G that I finished testing the day before yesterday, they are continuous 10A cells, it is a little better than the LG M36, but the best of four that I I have tested has not exceeded 3552mAh in continuous discharge at 0.2A, accurate 4.20v at 2.50v accurate (discharge current cutout set to 0.01A is 10mA, so I can not get better than that), concretely this cell does not reach the 3600mAh as its rated capacity indicates, but it does not really surprise me, because I tested 10 units of LG M36 a few months ago, it has the same indication of nominal capacity is 3600mAh, and the best M36 of the lot did not exceed 3543mAh too. The only things that can be credited to these two new cells (Samsung 36G and LG M36) is better internal resistance than any other high capacity cell that existed before (Sanyo GA, LG MJ1 and Samsung 35E) and better voltage performance than previously equivalent discharge compared to older models too. Otherwise, but it remains to be confirmed in time, the M36 and 36G have supposedly a longer life, that’s all that knows about these two new cells.
So it is better than the 35E, that’s great, this is the new best 18650 then (for mAh of course)
Huh?
They actually have lower internal resistance than the 3500mAh cells? That is surprising. Guess LG’s and Samsung’s cells are on a different level than the NCR18650G.
I was not talking about NCR18650G for comparison, but Sanyo NCR18650GA, LG MJ1 and Samsung INR18650-35E exactly.
The Pansonic NCR18650G, I would not even want if they gave me, they are more than obsolete cells, for that besides they are no longer manufactured and very hard to find new, for me they have their places only in a museum. The GA explode far G, if you buy a good rank of a good batch, it is true every time.
Interesting thread, even if it left the OPs original question behind 2,5 pages ago!
What seems to account for the varying specs from different manufacturers is whether they state “minimum capacity, ”typical capacity” or “maximum capacity”.
Furthermore it is probably also affected by which bins that get available for “hobby users” as single cells.
If all of the “A binned” cells go to battery pack manufacturers, and all we are getting are the lower bins, more variance in internal resistance and capacity is a given result of this.
This is something that will vary, not only between different manufacturers, but also between cell models, as they are adopted for different packs by different makers of such.
Yet another factor is how exact the manufacturing process is for different brands and models, ie: what portion of every batch ends up in which bin.
This may also vary from batch to batch.
(A good example from another, yet somewhat related, manufacturing is CPUs and GPUs. Where certain models and batches turn out so well that the ones sold with lower specs, which is typically where lower bins end up, are really all from the highest bin and just underclocked. Making some extremely reliable for and sought after by overclockers. Nowadays though, most are made like this, and the makers of CPUs and graphic cards have gone to great lengths to lock the lower spec products from overclocking and unlocking disabled cores and whatnot).
When it comes to “real world performance” the variation is a lot more due to what the individual user actually uses something for, and how.
I, for instance, use a D4 with quad 219Cs. On top of that, I mostly wear a suit and want my EDC to fit in a vest pocket, so about 10cm/4” is the longest anything that will fit properly.
Hence, I use a shorty tube and an 18350. (Just got myself five Keeppower 1835Ps for that and there really aren’t any competitors in either output or capacity in that size. Except other brands using the same cell).
I do however want the ability to screw on the long tube and get maximum performance and/or runtime with 18650s.
If I go “glamping” that includes a generator (and a PA system plus a bunch of DJs etc) in which case I can always charge my batteries. And if I’m bringing a vanful of gear anyway, I can also bring all of my cells…
If I go camping/hiking/biking/kayaking though, I’ll need to bring lots of spares and/or use the ones with the most runtime, given the way I use the light. This also applies to when I go to open air techno parties and don’t want to bring more than a small bag, yet might be away for the entire weekend.
Now, I haven’t owned the D4 long enough to really know what my “real world usage” really is. And summer “nights” here in Sweden consists mainly of dusk and dawn, never really dark.
When “glamping”, or in other words, arranging and crewing a 48h open air techno party on a small island, an efest 18350 lasted all Friday night, when I was actually working and used it at lower output to see what I was doing close up. On Saturday night though, I quickly “drained” a VTC6, and thought that the flashlight got a lot hotter a lot quicker. Although by then I was properly F’d up and mostly just having fun with my pocket sun!
My actual question:
The problem with such a compact and high power build as the D4 though, is that regardless of how well the battery handles high current, or perhaps even exacerbated by it, the emitters will get extremely hot in a very short time.
The worst case scenario though, would likely be with a cell that is just about able to continuously deliver the maximum current, as pulled through the FET by the low fV Nichias, while itself heating up quickly!
This is probably the case with the Keeppower (Yongdeli) 18350s, and in all probability with all of the high capacity “10A” 18650s as well.
I’ve read somewhere on this forum that the draw is somewhere around 16-17A on turbo.
For most applications, such as lighting a dark path or for close up work, I’m fine with the “highest” regulated level, ~150lm @350mA. And while the ramping interface is nice and allows for finding the perfect power level for any given need, I very much like to just “Let there be Light!” with a double click, and then get back to low with another.
So the question is: what will be the sweet spot in batteries for the ability to run it for a long total time on low while retaining the ability to also use turbo, preferably for somewhat long durations, given the restraints of the compact build and its inherent heat problem?
We do get really cold winters here in Sweden as well, but I’m not worried about that as I trust in the heat build up to take care of that. Based on lots of experience with a TrustFire light running both TrustFire and Sanyo 14500 cells. (Had to occasionally start on low, but never failed completely unless cell was already very low and temp below –15°C (toward 0°F).
I’ve already got a couple each of VTC6 and HG2 and plans to get a couple of 30Q and probably GAs as well while I’m at it, for further single emitter lights if not for the D4, where I do believe that they are still top dog.
Price really isn’t an issue, not because I print my own, but because I won’t be needing that many and won’t wear them out for years…
And lastly…
To really put the “High drain Vs High capacity” question to the test: (leaving 18650 size)
How about comparing the A123 26650, just 2500mAh, but LiFePO and rated at 70A continuous output, to a good 26650 cell with at least double the capacity, at a discharge level around what the other cell is rated for?
The voltage at which the high capacity overtakes the A123 might be a bad indicator as it’s a LiFePO… but still, sometimes looking to the extremes is the best way to determine the answer to a question where the difference is too small to be decisive!
And might be interesting for the D4S.
Just got in three 36G and here’s a comparison of them with a couple of now 2-year-old 35E cells. I am not impressed. Avg 2% higher capacity. Temp 32-34C through the run, had a fan a few feet away. The edge cells #1 and #4 were held in at the top of the bays by spring tension and the center cells #2 and #3 had magnets (those are the two ways to deal with too-flat flat-tops in the MC3000).
This was a 750mA discharge to 2.8V after a 4.2V charge to 90mA. I usually measure capacities a bit lower than rated, but pretty sad showing for the new cells in comparison. Not sure if it’s enough to complain to the supplier, but I’ll probably send them this as a FYI. Subpar batch? Normal variation between cells?
For use, they’re fine, as good as the other 3500mAh, but vs not-fresh 35E cells I would have liked to see better. Got them on sale $5 ea from 18650batteries so even with $5 shipping didn’t pay a premium. The 35E were from Banggood 9/2016 at $7ea. The 36G have circular indents on the bottom, which I hear is normal (extra safety “vent”).
Text version:
36G #1: 3195 mAh
36G #2: 3287 mAh
35E #1: 3184 mAh
35E #2: 3174 mAh
How many times were they cycled?
Were they all discharged and recharged by the charger?
Couple of times each (by the MC3000) when I got them a few days ago, same for the 35E two years ago (they saw very little flashlight use if any, stored at 3.7-3.9V). Just ran the 750mA test on these 4 tonight discharge maybe an hour after charge completed. Usually test at 500, but wanted to see a result before bed.
So for new cells 2% isn’t bad, 36/35=~3, and really, I don’t see a lot of capacity loss with storage, but 1 would be my guess. I have original Panasonic Bs that lost maybe 2-300mAh over many many years. Lot less than the calendar life data I see published.
Just looked at the 35E datasheet and they’re min 3350mAh with a 2.65V cutoff at .2C with C=3400 (not 3500). Can’t find a 36G datasheet yet but I presume it’s similar. FWIW, maybe nothing, the DC IR was about 55mohm for the 36G vs 45 for the 35E, but take MC3000 IR measurements with a grain of salt. I see 30-45 for 30Q/VTC6/HG2.
Maybe the improvement is mainly less voltage drop under load, hence the 10A rating instead of 8A?
This would mean the cell has higher Wh but that would not be visible form looking at mAh, a discharge graph like the ones from HKJ would be necessary.
So as far as capacity goes, they’re pretty much the same as the 35E, right? I think that’s what we were all predicting. How is this in any way sad?
Have you compared their internal resistance?
Have you measured their current output using a FET based driver?
Are they rated at 10 amp continuous? I haven’t seen any data sheets for it.
Edit, I guess datasheet aside, the stores are listing it as a 10 amp continuous cell. So that must be where the Improvement is.
I0A CDR rating vs 8A, yes. I wouldn’t pay extra for the 36G but then, I didn’t.
Argh, the MC3000 does Wh but the result is buried and I didn’t record it. I can rerun the test later but the next day or two I’m topping off 50 or so cells in anticipation of the hurricane (NC, USA).
No plans to do a FET driver test, they’ll be used in Zebralight SC600w MkIV Plus and SC64w primarily. I have a handful of budget lights, one of them probably FET, but all I’m sure of is most are 7135. Emisar D4 (XPG) OTW, that’s FET I think.
I have a bunch of 3500mah GAs and VTC6 already that have higher capacity than the 30Qs and VTC6 performs better too. But I want the highest capacity for my ROT66 with the 219B because I’m planning to use it as a work lamp to make use of that gorgeous tint.
Hey… if you think the minuscule run time increase you ’might see’ is worth the price of getting new batteries…… I say go for it & let us know how it works out. :+1:
