DQG Tiny 4th 18650 xml-2 review
125 posts / 0 new
vresto
vresto's picture
Last seen: 2 days 12 hours ago
question-is possible to open this flashlight?the output is too low for me.want change driver.but which side switch driver which gives 6 amps as the fet driver could fit for this flashlight?anyone tried it already?
EDC-Amutorch X9 XHP50 nw,Sofirn If-25A cw
Headlamp-Thrunite TH30 nw
Agro
Agro's picture
Last seen: 1 hour 14 min ago
There is no space for that because DQG uses a single PCB with both driver and LED.
However, I’ve seen 2 ways of finding the space:
  • use a smaller reflector, which doesn’t fill the head fully
  • use a Carclo triple optic
I’ve seen Ledil Satu triple considered too, but haven’t seen anyone actually using it
finges
Last seen: 1 day 4 hours ago
Have a look at this thread http://budgetlightforum.com/node/56536
Also a conversion to triple with optic is possible, unfortunately the pictures are gone http://budgetlightforum.com/node/39827
vresto
vresto's picture
yes i see…pics are dissapeard
the nichia mod-is it much more powerfull than the stock?…….
Agro
Agro's picture
There were 2 triple builds on this forum (one with Tiny 4th and one 3rd) and at least one on fonarevka. So you may be able to find the pics.
vresto
vresto's picture
yes i see it already….but….thats too much for me…..sadly.hard to open,hard to change…….its a pitty.so nice flashlight.but not enough bright
Pete7874
Pete7874's picture
Last seen: 9 hours 7 min ago
Is there an 18350 tube that would work with DQG Tiny 4th?
wle
wle's picture
Last seen: 1 day 7 hours ago
No, it would have to be a totally new body, there isn;t a tube per se.
it;s just a cap and a main tube, there is no middle section to be shorter
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Pete7874
Pete7874's picture
What do you mean there is no middle section?…
wle
wle's picture
oh
well there it is!
Smile
mis remembered
i guess you could make a short tube but i have never heard of one for sale
wle
-Greg Lemond.
Pete7874
Pete7874's picture
Right, I was just wondering if maybe a shorty tube from some other light would work…
agnelucio
agnelucio's picture
Last seen: 2 days 14 hours ago
The Nichia 319 mod was for better Tint/CRI, better UI, and higher efficiency,
not for higher output.
The XML2 in the stock light gets very hot while the body of the light remains fairly cool.
If you modify it with a proper PCB and heat transfer for the LED, you will quickly realise that it can only dissipate approx 10W heat maximum
(which is what an XML2 or XPL or Nichia 319 etc will generate at 3A).
Any more power than that and you are just going to burn your hand faster.
Tailstanding indoors with no airflow, mine gets hot and thermal throttles on high after a minute or so.
If you want a nice compact EDC light with good runtime and decent output for most common tasks, modify this light if you want, but keep the max level under ~10W.
If you want any more light than that for any extended period of time, get another, larger light with more surface area to dissipate heat.
pennzy
pennzy's picture
Last seen: 6 min 22 sec ago
Was the switch improved on new ones ?
wle
wle's picture
what do you mean by ‘new ones’?
i had one from dec 2016 that i complained bitterly about, due to the terrible switch, design, and or manufacturing that made it come loose
wle
-Greg Lemond.
pennzy
pennzy's picture
wle
I see a gear best deal today . Do you think the ones being shipped today have improved ? Will epoxy help ?
wle
wle's picture
epoxy might help make it stronger against the pushing, not sure if it would have thermal implications, or if it would permanently fix it.
i would guess the current ones, still calling themselves “IV”, are the same.
theoretically you could write to the head of the company and ask, but i never had much luck with that.
if there are new versions, he may not know what gearbest is selling currently.
wle
-Greg Lemond.
wle
wle's picture
also i don’t see any deal – they have been as low as $13.99 recently
-Greg Lemond.
pennzy
pennzy's picture
I did not know that . I’ll wait for better deal . Thanks .
somnambulism
Last seen: 1 year 1 week ago
Dutcheee wrote:
I wasn’t aware or I forgot.. Big Smile So, what’s the cut-off voltage?
2.8V in my test.
fedcas
fedcas's picture
WOOOT?? Any deal around? I’ve seen there’s a code for 26 USD at m4dm4x’s… do deals at 20 usd or under happened recently?
Also, the 4th version it’s been produced for a long time, any news about maybe a new version in the air?
exactly the information that I was looking for in this thread… with the new 18350 cells around, such this light screams for a short tube of some kind…
fedcas
fedcas's picture
no luck I guess? Sad
Agro
Agro's picture
I wonder how can I improve performance of my Tiny.
I like the beam profile, wouldn’t want to make it much floodier. Or much throwier either.
Turning it to a triple (f.w. triple Oslon Black) is far beyond my skills.
Swap LED?
The LED included is quite good, I don’t see any stock emitter that would be 3V, significantly more efficient and not floodier.
Dedomed Samsung LH351D might be an improvement, but a small one and I feel it’s not worth the effort….
Res-modding?
I’m not sure even minor current increase is a good idea without improving thermal path.
But maybe…..should enable more improvement than LED swap…
Improving thermal path?
Dunno, maybe potting with Arctic Alumina and attaching a copper plate on top of the light engine would enable me to spread some heat outwards?…
Painting interior with white heater paint?
There is GITD strap inside and it clearly glows. Which is an evidence that there’s stray light hitting flashlight walls. Painting white would put some of this light in the spill…Has anyone painted the interior of a TIR light with white paint and reported the result?
finges
The only thing I would like to do is swap the LED to LH351D 90 CRI. But it is quite hard to do because it sits directly on the driver pcb.
toddcshoe
toddcshoe's picture
Last seen: 1 hour 29 min ago
Swap LED?
Res-modding?
You just talked yourself into not modding it. It is really perfect for what it is. Plenty of light. Plenty small. Easy UI. Just plain works. It doesn’t even get that hot, sure it gets warm but not D4 type hot. It is one of my favorite all around lights. If it ain’t broke, don’t break it. LOL
"Everywhere I go, there I am"
Agro
Agro's picture
Would that:
http://kaidomain.com/S026103-19mm-x-17mm-x-1mm-Glow-in-the-dark-Water-ti...
o-rings fit the Tiny?
I’d like to make it glow a bit brighter…
Agro
Agro's picture
While potting the Tiny 4th light engine, I let some glue escape to the switch area.
The switch got partially glued….
The glue was silicone based and I managed to somewhat clean it out. The light turns on, but the switch got much harder to press and lost the click feeling.
I’d like to try to replace the switch…but for that I need a replacement.
Does anyone know the replacement or can tell what should I check to find something suitable?
wle
wle's picture
that is going to be hard – both to find and to replace..
even then, i think the design is poor – it is likely to break off like 2 of mine did
wle
-Greg Lemond.
agent80
Last seen: 5 hours 49 min ago
There seems to be a trend towards a low mid mode. 80 lumens is ridiculously low for a mid mode. A mid mode needs to have a good amount of light with and a good balance of run time. Ideally between 150 – 220 lumens.
wle
wle's picture
what i would want in a UI would be 7 or 8 steps, evenly but logarithmically spaced, with a really fast single-click switching
like the astrolux S1
steps would be like 1-3-10-30-100-300-1000
and a way (long click) go to the previous level
the S1 comes close but its steps are not spaced like i would like
the DQG tiny IV just has 3 somewhat useful levels and a turbo
the low isn;t low enough, the step to M is too big
then H and turbo are too close
ack
wle
-Greg Lemond.
Dutcheee
Last seen: 1 week 23 hours ago
You should mod it to a triple!
IMO the host is very nice, but from the factory it is not an impressive light.
