[M4D deal ALIVE] Astrolux S43
What is the charging rate? It says fast charging so I assume it’s 1Amp charging current but isn’t that too high for most 18350 cells? Can you tell us something about the UI?
Filled in the form
Charges at 0,5A probably like the original S42.
:+1:
Interested
Any luck?
It does say constant current, but I’m pretty sure it’s using a FET driver. We need to get clarification on this.
A lot of 16340 lights charge at 1A. It might hurt the capacity of an 18350 a bit more over time compared to a lower rate, but it shouldn’t be that big a deal. I’d actually prefer 1A. If the capacity of the 18350 drops after a couple years, just replace it.
I’ll see if I can get some info from TA.
Yep, it’s a FET+1.
Charger circuit is 0.5A.
Uses NarsilM v1.3.
I setup the charging for 1A at first but they were worried about overheating the cell and possibly causing issues with cheap cells in testing and I had to agree, better safe then sorry so I dropped it down to 500ma charge rate.
You can technically raise it back up by swapping out a resistor if you really wanted.
groupbuy is LIVE!
because banggood has their 12th anniversary i was allowed to post the deal public
Link: Astrolux S43
CODE: MPACP
PRICE: 28 US$
all participantd got a mail also
THANKS for helping make the deal happen
Ordered the Nichia 219C
Thanks Martin
Made my payment just now…
the Wait begins! lol
Thanks Stephan
Both version ordered, thanks Martin :+1:
Nichia ordered. Thank you for organising
Ordered Nichia. Thank you!
Thank you. Have a good time :slight_smile:
Can we expect the same beam pattern as the S42?
Ordered the XP-G3.
Thanks, grabbed the Nichia 219C
