The VTC5D (late 2017, early 2018) is supposed to be the latest, greatest chemical mix. It’s a bit better than the older VTC5A (2016).
When it comes to the major battery manufacturers, it seems like their newest version always performs better than their older version. They are always finding small improvements. (Don’t qoute me, I’m talking about in general they always make improvements)
Yep, thanks Kawi. The 30Q’s I’ve been using are showing around 25 IR. Compared to the single digits of my 30T’s (07-09) 25 is pretty high.
Thinking about trying out the offset boring with a 4 jaw chuck to see if I can open the battery tube holes in the M43 a bit to accept the 20650 LG HG6, pretty dang close to the 30T really in a slightly smaller form factor. (I could offset bore towards the middle and not bother threads or anything, in theory) Wish I had a mill….
Still thinking about making a new tube for my GT mini to use a 30T…
BLF GT mini with short and reg tubes, BLF GT with short and reg tubes. Not sure that I’ve seen these all together or at least recently, so here they are.
When a battery manufacturer designs a battery they have to adjust the chemical mix to give them what they want. They can go towards the direction of high capacity at the expense of less amperage output. Or they can go the other direction and make it have more amperage output at the expense of less capacity.
Every new battery seems to perform better overall. An example is the old Sanyo/Panasonic 3400B compared to the newer 3500GA. Max continous amperage went from 5A to 10A and capacity went up just a tiny bit.
To my knowledge HKJ has not tested the VTC5D, 24S or 20S. Maybe you are refering to Mooch?
Do you have a chart of these tests? I’m curious to see it.
Yeah, I think you mean Mooch. He even explains in his report that you have to sacrifice capacity if you want amperage and vice versa. Here is a chart I found. I’d this the chart your refering to? The batteries are a bit different.
Thanks for the info… i have 5 sony vtc5d. I dont see much improve over the sony vtc5a… vtc5d are damn expensive $10 each…, i personally would use sony vtc5a if i can… its much cheaper…
hm i think my mini has a problem with the button now It barely works i just put in a fresh charged 30q battery and its like not coming on, it gets power and i have to click like 10 times or more for it to come on suddenly i dont get it? if i double click a few times i get high mode and cant if i hold in button ramp. If i lose tailcap and back again the button turns green so idk it wasnt like this last night,
anyone else have issues with button?
I should send neal a mail maybe but this sucks never had a button go bad on a light before like this…
I had a switching problem with the mini-GT that sounds like yours. It was not there when I received it but it started after some playing with the light. I contacted Neal about it and he was helpful and prepared to compensate me for it, but also asked if I could look into what the underlying problem was (fair enough, he knows that I’m into modding flashlights). It did not come as far as unsoldering the switch to see if the problem was inside the switch (I ordered some spare switches on aliexpress for a dollar) because the switching started working again after some more use and letting the light run hot a couple of times. Since then the switching works fine, although you never know if it stays that way of course.
