The 15C version is labeled as 15C, and that label makes it different from the ‘normal’ AW 550mAh 16340 cell, no other visual differences. The batteries in the link do not have the lebel, and it is also not mentioned in the description.
I have tried to order there, but it did not work for me. I can’t remember what went wrong, it was a few months ago, probably no stock despite the listing.
I checked them again and indeed they seem to still have them in stock (for some time already because AW stopped making batteries more than a year ago because of some disaster at their facility), but including everything, to buy two of these batteries costs me 30 euro’s (33 dollar), and I would still be nervous if they do not send me the non-15C version. Thanks for the link though
Thanks for HKJ’s hard work, I have a question for “Protected 16340 (CR123) sized batteries with a nice current output.”,sorry i do not give you the specifications. the shockli 16340 700mah is unprotected battery.
Yup those are it. No real test with graphs or anything close. I have several high powered modded lights and I just did a simple lumen ceiling bounce test and the lumens were not too far off. And it was able to sustain the output pretty well also.
I ordered two button top Imren 700’s to try. I purchased them off ebay for 10 bucks shipped. I’ll try them out once they arrive.
Link for you djozz. Shade E-Vaping
They been around since 1999 have over a quarter million sales with almost a perfect feedback and lots of good reviews, I’m guessing authentic and cheaper than Imrbatteries. If they test good, I may buy more but the shipping price doesn’t change or penalize you for only buying 2 cells to test.
If they are not authentic, I get my money back. Says they are authentic in the description.
I tested the IMR 16340 Imren at a 3 amp load. I got 340 mah at 7 minutes before tripping the 3v cut off. It’s about average with the other top name brand 16340 cell’s. The IMR 16340 Trustfire (red-gold) is still the best 16340 cell I have tested at a 3 amp load. It did a little over 500 mah at 10 1/2 minutes at a 3 amp load.
I just ordered 6 of the TF red/gold 16340s from FastTech and people just need to remember that on some of the older (and perhaps newer?) lipstick lights, with reverse polarity protection, the flat tops aren’t going to work.
I always tell people that most good cells will test out well in the beginning, but the real issue is how many months do you get out of them before they’re trash?
I won’t buy Kinoko, even if they’re still in business and I won’t buy Soshine any longer, because they didn’t last long for me.
the shockli 16340 600mah would meet your requirements. the capacity is over 500mah at 3 AMP load.
The shockli 16340 600mah have better performance than shockli 16340 700mah at high discharge current.
The link and HKJ’s graph both are showing the Windyfire IMR16340 600mah which looks to be a very good cell for high current drain in a 16340 battery format.
Are you stating that Shockli is Windyfire or that Shockli is using the same cell. Its not very clear what you are stating the way it stands.
I also noticed that Mtn.electronics test review link also brings you to HKJ’s Windyfire test.
