Interested in the M3 Pro: Full Pack – NW
Thank You
Thank You
Same here.
Is the M3 PRO the smallest rechargable 16340 light?
Nop, the Olight S1R Baton is smaller! However, it is recharged by a proper magnetic cable !
EDIT: And it is only rechargeable with a specific battery from Olight!
It also has a thin TIR lens instead of a taller reflector just to shorten it.
Tom6:Is the M3 PRO the smallest rechargable 16340 light?
Cool pic. You can tell the reflector takes a lot of space, then I guess there’s no recharging circuit near the driver which also saves space. They really crammed it tight. Lol
Interesting M3 pro cw full pack
The S1 mini isn’t rechargeable (wish it was :person_facepalming: ) , but does it take in-built USB rechargeables?
Yes
MascaratumB:The S1 mini isn’t rechargeable (wish it was :person_facepalming: ) , but does it take in-built USB rechargeables?
Yes
Nice Thank you! I was just asking cause I thought that due to size it would not take them ! Being that way is nice
Okay, it’s the S1R that has the magnetic charger base. It seems to be a few mm taller than the S1 to it’s right.
Avoid battery with built-in charger. My brand new KLARUS went into self-destruction when i kept it in the box alone for less than 3 months.My other Nitecore NL1826R anode became hot (>50°C) when i removed from a Nitecore light. Top plastic cover deformed by the heat.
I don’t know if you can say that all brands of this battery style are bad based on just 2 examples.
Have you figured out the cause of those battery failures? Was it anything to do with the charger circuit or was it just bad batteries?
I don’t have any of this battery style simply because I don’t like having to take the battery out to recharge it.
freeme, can you post it here Flashlight with in-built charger OR flashlight + battery with in-built charger? ?
Or can I quote you to put on that thread?
I have few more models that i don't really use. Maybe i spend some time with them then share my findings over there later.
freeme:Avoid battery with built-in charger. My brand new KLARUS went into self-destruction when i kept it in the box alone for less than 3 months.My other Nitecore NL1826R anode became hot (>50°C) when i removed from a Nitecore light. Top plastic cover deformed by the heat.
freeme, can you post it here Flashlight with in-built charger OR flashlight + battery with in-built charger? ? Or can I quote you to put on that thread?
I have few more models that i don’t really use. Maybe i spend some time with them then share my findings over there later.
MascaratumB: freeme:Avoid battery with built-in charger. My brand new KLARUS went into self-destruction when i kept it in the box alone for less than 3 months.My other Nitecore NL1826R anode became hot (>50°C) when i removed from a Nitecore light. Top plastic cover deformed by the heat.
You’re right Better “testing” than early conclusions on single episode! Still, it is a data that makes me think about these batteries…
But, the thread is “On The Road” so let’s keep rolling Sorry for off-topic! :arrow_right:
When is this torch likely to appear?! My status on GearBest is shipped, has been for some time now, but guessing as there are no reviews yet it’s probably not shipped at all?
Mine left the China sorting center on Sept 4th. It may be on its way to the USA right now. The delivery window is Sept 5th to 17th. So maybe I’ll get it some time this week. You never really know how long it will take for shipping, 2 to 4 weeks is common. It will eventually get there. Lol
I don’t expect anything new as far as reviews go. It’ll probably have the same mode spacing as the original M3. About the only thing that’s changed is the built-in charging.
