The switch LED’s only light up if you plug in the USB for charging. You can change this by moving one of the wires on the driver if you desire to re-enable the Narsil indicator LED.
Correct, the pinout will need to be changed a little. Pretty sure that TK make this fairly simple in Anduril.
If it is popular I am sure someone will at some point as well.
Good, which wire do I need to move? - I don’t care about charging in the light
Texas_Ace: joechina:So it does breath green and and I can switch this off?
I only have the prototype drivers and I am not sure what the final drivers / wires setup will be at this point.
This is the charge PCB design though:
You will just need to move one of the wires from either the Charge or standby ports to the main driver IND pad.
The charge pad should be the red LED and the standby the Green LED but like I said, I assembled my driver myself, not 100% sure on the final driver.
Ok, thanks TA
I got permission to post the prototype light I got, these are pictures from Mateminco, the ano looks a lot better on mine in real life then the picture look.
Thank you
The prototype tube does look better. Even the production light is sorely tempting me, though. I’m not usually up for this type of light, but wouldn’t mind an easy way to try the Narsil UI.
Hi TA, is a straight MCPCB swap easy to do on this light??
Yeah, that is fairly simple, just unscrew the bezel, remove optic, swap mcpcb, reverse process.
any thoughts about replacing the leds with xplhi?:laughing:
KevinZA1988:Hi TA, is a straight MCPCB swap easy to do on this light??
Thanks
I just got a shipping notice so someone is working in China
I like the tip. Good for defence against drop bears.
You want to use the spiked tip on the back of this little flashlight to fight bears? :person_facepalming:
shirnask: Texas_Ace: joechina:So it does breath green and and I can switch this off?
I got the info from TA that the green LED works as driver LED, like in other NarsilM lights. The red LED is on when charging and off when finished.
It is a last minute change. We will see if all shiped lights got this.
Sillen:I like the tip. Good for defence against drop bears.
It’s not “bears”: it’s drop bears
Are there stand alone charge pcb’s like this for sale anywhere?
Texas_Ace:This is the charge PCB design though:
Not that I am aware of. The design will be uploaded open source but not sure it will do any good as I can not find the IC they wanted to use outside of the china. The only way I was able to test it was with the prototype they sent me.
Thanks TA
Got one in today and the switch light is on when light is off - don’t have to change anything - and I now have protection against drop bears
Lucky you! Mine arrives in Melbourne last Friday but Australia Post haven’t delivered yet, awaiting clearance, so I’m still vulnerable!
