Ramp top is not adjustable. 1800 lumen is safe and sustainable output in this light with some warming. Turbo is I think 3000 lumen will be in factory data but they measured 3500 on a prototype. Better than tell more and get less. Visually to the eye it is no t a huge jump from 1800 to 3000.
If they use this firmware in the SP70 I think there will be ramp top at about 4000 lumens and turbo about 6-7000. My XHP70.2 MF02 with Andúril is setted up ramp top at 4000 and turbo at 8-9000 depends on battery level and type.
Here is the complete menu:
4 mode Groups:
Group 1: 500lm
Group 2: 100lm—700lm—1800lm
Group 3: 10lm—100lm—500lm—1800lm
Group 4: Ramping from 1lm—-3500lm
In any mode, including OFF, hold 1 second to go to Moonlight
In any mode, Double-click to go to Turbo 3500lm, one click to go to the previous mod
Group 1/ Group 2/ Group 3:
Short click the side switch to cycle through modes: Eco→ Low → Mid→ High→ Eco→ Low→etc.
Press the side switch for 0.5 seconds to enter Standby (main led is off). 4 Four fast clicks convert from one group to the other, 2 blinks confirm the change.
Group 4: Ramping
Press and hold side switch to ramp up or down. Ramping changes direction when press button again within 1.5 seconds, same direction when ramping again after 1.5 seconds. The light blinks when it reaches Moonlight or Turbo. When the light is on, click to Standby.
No matter in which group:
Hold and press the side switch for 1 second to enter Moonlight from Standby, one click returns to Standby.
Double clicks to activate Turbo mode from On / Standby, one click returns to the last brightness used or Standby.
Triple clicks to activate Strobe mode from On / Standby, one click returns to the last brightness used or Standby.
Memory Function: The last brightness used can be memorized when convert from Group to Group. When it goes back to the group, it starts from the remembered brightness level.
OFF
Press and hold the side switch for 0.5 seconds to enter Standby (except in Ramping Mode).
Click the tail switch to Cut Off. Please click both tail switch and the side switch to turn on if the light was in Standby last time.
Advanced Temperature Regulation (ATR) technology:
If the head temperature reaches 50 ℃ (122 °F), the flashlight will automatically throttle down to lower mode to avoid overheating
Hi and thanks for taking the time to reply everybody.
@DB Custom - the light has spring bypasses at the head and tail cap so would the battery length difference (ie spring compression) be that much of a concern re the loss of output?
I have been fiddling with the interface and am still having issues with it getting stuck. I will persevere as it seems like a really nice light outwardly.
Yes. Battery compression strength is extremely important, especially in regards to springs.
Low compression force by the battery in the spring can result in very high contact resistance, especially if the spring wire isn’t thick(0,8mm in this case) and if it’s made of a hard material, like steel, although a gold coating helps quite a bit since it’s soft, but the problem still remains.
That means two things to fix it in the Sofirn C8F for complete 18650 compatibility:
1. Making the springs longer and thicker to lower contact resistance significantly without changing the material.
2. Solder a small 2mm thick brass button on top of the springs. You will get maximum compression, therefore lowest contact resistance possible if you use it with an 18650. It would work with a 21700, granting you maximum performance possible by making the spring fully compressed, but you would probably sacrifice protected 21700 compatibility.
Just to be clear, I wasn’t questioning the max lumen output of this light. I was asking whether it can reach its max output in ramping mode, or if ramping mode is limited to some lower output. Some statements said ramping is limited to 1800 lumen then you have to press something to kick it up to max, while others said ramping goes all the way to 3500 lm.
Pretty sure the eye can’t compare 3500 lumens of light between different flashlights. You need a light box. The eye can easily misread hundreds of lumens, even a thousand. A slight difference in the beam profile or the tint of the output, the eye reads it differently.
The light box shows even small differences, whether or not the light box is 100% accurate it IS accurate at showing differences between lights or modifications. And that’s why we as individuals have light boxes, to show a gain or a loss when we are modding lights.
It was Moleyman69 that said his new 21700 light seemed weaker than his older 18650 version. I was wanting him to try double clicking to see if it improved.
I imagine we will get some good tests in the next week as more lights get delivered.
DB should have been refering to Moleyman69’s post about the new model C8F looking weaker than the older model. Moleyman69 does not have any measuring devices, just his eyes. I hope this clears up any confusion.
I do have measuring equipment - the light meter I mention in my first post #991 that produced the ceiling bounce comparison Turbo mode numbers that I listed - but it isn’t a very expensive one but it does seem to be consistent.
Also, it is the double-click Turbo modes that I am comparing.
Hope this helps to clear up any misunderstandings.
Okay.
A ceiling bounce test between lights that have the same beam pattern can be a good comparison.
So you have both versions of the C8F, but only an 18650 battery?
You’ve tried the new light at the top of the ramp and a dbl clk and it’s still weaker than the old light?
Keep in mind that part of the reason the new light is rated at a higher lumen is because of the more powerful 21700 cell. So in theory, both your lights should have about the same output.
What DB said about the longer battery tube on the new light not pushing the springs very hard against the battery ends might be a reason. If it pushes with very light contact it can create a lot of resistance.
Here’s something you can try. Take a short and thick piece of wire and bypass the tail cap. Run the wire between the negative battery end and the bare metal on the battery tube. At the same time push on the battery so it presses against the front spring firmly. If doing this gives you equal output to your older light then we know the light itself is okay.
Like with all new lights, you should make sure the driver and tail switch retaining rings are tight and haven’t loosened up in transport.
