Ended..
LUMINTOP BLF GT70, GT, GTmini!!!
VALID TILL Sep 20, 2018
Interested in Ti Pen
ASTROLUX C8 XP-L HI 1300lm
$19.95 | FLASH SALE
ASTROLUX MF02 XHP35 HI 3000lm
$79.95 | FLASH SALE
ASTROLUX MF04 XHP35 HI 2700lm
$175.2 | Code: 7A3E05
ASTROLUX S1 XP-L 1600lm
$20.89 | FLASH SALE
BLF A6 XP-L 1600lm
$17.99 | FLASH SALE
BLF Q8 4*XP-L 5000lm
$49.99 | FLASH SALE
Curious about the TiPen :slight_smile: Thank you.
We will work on Ti pen after 12th Anniversary sale.
Imalent MS12 12 x XHP70 53000lm LED Flashlight 8 x 20700/4300 - $DEAL - / Proceed to Store.
Sofirn Q8 4*XPL HI 5000LM Powerful LED Flashlight available for Sale now.
Invalid coupon for S70S
Sorry, ThorFire promotion for 12th Anniversary has ended.
moved.
Our friend's new store!
3* CREE XPL HI or Nichia 219C LED 3000lm
Hi Freeme,
Is there any chance to get this code for the Nitecore Concept 1 from your webpage alive again? Gearbest offers the Concept 1 but the code from your website does not work.
Cheers, Thomas
[AliExpress - Flash Sale] Sofirn New C8F 21700 Version Powerful LED flashlight Triple Reflector Cree XPL 3500lm Super Bright Torch with 4 Groups Ramping
Price: $30.93 ( usual $41.16 )
Coupon: Store promotion - additional USD$2 OFF (>$25 order).
Store: http://s.click.aliexpress.com/e/KmQ486k
Specification:
  • 3* CREE XP-L LED with a lifespan of 50,000 hours
  • Working Voltage: 2.8V-4.2V
  • Battery Options: One 21700 Li-ion battery or One 18650 Li-ion battery(Suggest 21700 battery)
  • Dimension: 149mm (length)*44.6mm (head diameter)
  • Weight: 200±2 gram (without battery)
  • Flashlight body: Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized anti-abrasive finish to get solid built body, anti-crash geometry and better heat exchange.
  • Toughened mineral glass lens with AR coating.
  • IPX8 Waterproof (submersion up to a maximum depth of 1.5 m underwater for up to 30 minutes).
  • Reverse polarity protection from improper battery installation.
  • Advanced Temperature Regulation (ATR) technology: ATR will adjust the brightness level automatically when the driver temperature reaches 50℃ (122 °F) to prevent overheating.
  • Power Indicator:
    • The LED indicator on side switch blinks in green for 5 seconds when turns on.
    • LED indicator is Steady Green if the voltage is between 3.4 volt to 4.2 volt.
    • LED indicator is flashing Red if the voltage is between 3 volt to 3.4 volt.
    • LED indicator is rapid flashing Red if the voltage is between 2.8 volt to 3 volt.
    • The flashlight turns off automatically if the voltage is lower than 2.8 volt. Please insert new battery.
TI Pen please :slight_smile:
Will find out the updated price for you. [quote=Lux-Perpetua]
Hi Freeme,
Cheers, Thomas
[/quote]
Unfortunately. I was told that they were not allowed for export. I will continue to monitor the situation.
Very quick flash!
It's a 24hrs sale. I will try to get more offer from Sofirn.
