Is there any chance to get this code for the Nitecore Concept 1 from your webpage alive again? Gearbest offers the Concept 1 but the code from your website does not work.
[AliExpress - Flash Sale] Sofirn New C8F 21700 Version Powerful LED flashlight Triple Reflector Cree XPL 3500lm Super Bright Torch with 4 Groups Ramping
Battery Options: One 21700 Li-ion battery or One 18650 Li-ion battery(Suggest 21700 battery)
Dimension: 149mm (length)*44.6mm (head diameter)
Weight: 200±2 gram (without battery)
Flashlight body: Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized anti-abrasive finish to get solid built body, anti-crash geometry and better heat exchange.
Toughened mineral glass lens with AR coating.
IPX8 Waterproof (submersion up to a maximum depth of 1.5 m underwater for up to 30 minutes).
Reverse polarity protection from improper battery installation.
Advanced Temperature Regulation (ATR) technology: ATR will adjust the brightness level automatically when the driver temperature reaches 50℃ (122 °F) to prevent overheating.
Power Indicator:
The LED indicator on side switch blinks in green for 5 seconds when turns on.
LED indicator is Steady Green if the voltage is between 3.4 volt to 4.2 volt.
LED indicator is flashing Red if the voltage is between 3 volt to 3.4 volt.
LED indicator is rapid flashing Red if the voltage is between 2.8 volt to 3 volt.
The flashlight turns off automatically if the voltage is lower than 2.8 volt. Please insert new battery.
Will find out the updated price for you.
[quote=Lux-Perpetua]
Hi Freeme,
Cheers, Thomas
[/quote]
Unfortunately. I was told that they were not allowed for export. I will continue to monitor the situation.
