Same here, Iâll toss it on the ol TA Lumen Tube. Lol
I canât do compatibility, though because I donât have the original.
Please see post 985
DB should have been refering to Moleyman69âs post about the new model C8F looking weaker than the older model. Moleyman69 does not have any measuring devices, just his eyes. I hope this clears up any confusion.
Hi everyone
I do have measuring equipment - the light meter I mention in my first post #991 that produced the ceiling bounce comparison Turbo mode numbers that I listed - but it isnât a very expensive one but it does seem to be consistent.
Also, it is the double-click Turbo modes that I am comparing.
Hope this helps to clear up any misunderstandings.
Thanks again
Moley
Hi everyone
Thanks again
Moley
Okay.
A ceiling bounce test between lights that have the same beam pattern can be a good comparison.
So you have both versions of the C8F, but only an 18650 battery?
Youâve tried the new light at the top of the ramp and a dbl clk and itâs still weaker than the old light?
Keep in mind that part of the reason the new light is rated at a higher lumen is because of the more powerful 21700 cell. So in theory, both your lights should have about the same output.
What DB said about the longer battery tube on the new light not pushing the springs very hard against the battery ends might be a reason. If it pushes with very light contact it can create a lot of resistance.
Hereâs something you can try. Take a short and thick piece of wire and bypass the tail cap. Run the wire between the negative battery end and the bare metal on the battery tube. At the same time push on the battery so it presses against the front spring firmly. If doing this gives you equal output to your older light then we know the light itself is okay.
Like with all new lights, you should make sure the driver and tail switch retaining rings are tight and havenât loosened up in transport.
Hi
I have ordered a couple of Sofirn 21700 cells to try and see if they help.
Still getting nowhere with the lock ups though
Thanks again all for taking the time to reply.
Enjoy your weekend
Moley
Hi
Enjoy your weekend
Moley
Did you successfully figure out how to switch from ramping to one of the other modes?
Iâm still not sure how itâs done. Lol
You never explained what the lock ups where doing. Does it just stop responding or does it not register all of the clicks properly? Do you think your switch may not be making good contact or does it seem more like something in the software that is hanging up?
Ordered 2x hosts on 8/29 and it looks like maybe it was finally shipped today but the tracking is pretty vague.
I just stuck an 18650 battery in to check performance in comparison to the 21700 and measured 420 lux for the 18650 against 460 lux for the 21700. The 18650 was a decent Klarus high current one.
So there is a bit of difference. Both batteries were fully charged.
Hi,
With the light on and in ramping mode try clicking the side button 4 times on quick succession - the light should blink 2 times indicating that it has switched back in to Group 1.
Regarding lock ups Iâm not sure if it is the side switch not responding or the light just âcrashesâ but for example when clicking between levels (not groups) I have had the light go Low > click > Medium > click > High > click > Low > click > Medium > click - nothing still in Medium > click - still nothing, still in Medium > click and hold - sometimes the light stays on other times it goes off. Then I pull the battery to start again.
Hopefully, the new cells might help shrugs - fingers crossed
Thanks again,
Moley
Hi,
Thanks again,
Moley
Hmmm, I donât think the battery is going to have any effect on the switch.
Itâs possible the switch may not be making good contact internally or the rubber cover is not centered. Iâm not really sure. You could try unscrewing the bezel on the switch and removing the rubber cover then push on the metal switch directly and see if it still does it.
There is another way to test it by bypassing the switch, but I donât know how familiar you are with electronics.
Hi Jason,
I know what you mean about the batteries but you never know.
I donât really want to start pulling the light apart as it kinda works at the moment and I would probably kill it completely if I were to start fiddling too much
Given the number of Sofirn lights that I already have that work absolutely fine and the bargain price that they are, to get one that is a bit faulty isnât really the end of the world I guess - just a little disappointing.
All the best,
Moley
Hi Jason,
All the best,
Moley
You can still contact Sofirn about a warranty. They may ask you to make a video showing the problem. Some companies do that. See what they say. You shouldnât just accept a faulty light.
Door to door 8/25 - 9/22. Magnifique!
If you get it in September, thatâll be pretty good.
Once it gets the âprocessed throughâŚâ part, itâs pretty much incommunicado âtil youâll get the âarrived ISC Los Angelesâ email or whatever. Could be a week, could be three.
Hi all, I wanted to ask the Sofirn community for advice please. If my C8F was sent via ePacket to me in California on 8/25 and the last update was Processed through Cantonâs sort facility on 8/26, should I just sit tight and hope it arrives in the United States this week?
I would like a feedback on typical turnaround and update expectations. Is it futile to contact Sofirn or the local USPS office, as there is nothing they can do, no further information is available beyond the tracking? Thanks.
What do you think Sofirn could actually do? Pretty much nothing. You can call your local post office if you want.
My packages from China typically take two to three weeks. Occasionally it may take up to 2 months. Once it gets to the US it moves pretty fast.
Thank you Lightbringer and JasonWW. That both answers my question, and gives me confidence that this advanced technology will be in my possession soon enough. :+1:
Exactly. My new 21700 host is on the way to Mars via Theiranus and will probably be here sometime next millenium.
My friend in Dubai sent me a package today that will be here Wednesday. Go figure.
Thanks to Dale
Like he said, once it hits âsnailmailâ it moves pretty fast, but itâs the barge coasting across the ocean that takes most of the time. That, and sitting on the docks in a cargo container, being packed/unpacked, etc.
I once ordered 2 lights from Sofirn within a day or so. First one mustâve just caught the tail end of the still-got-room barge and I got that pretty quickly, but the second one missed the boat, literally, and took a month or more.
âRegular shipmentsâ across the ocean are pretty much âwhenever the barge gets filledâ. Neither Sofirn nor the USPS have any control over that. Talk to Maersk or whoever.
