Sofirn Q8 group buy (gb closed, but try PM to Sofirn for discount)
In case you don’t miss the information. Sofirn Q8 is available in our aliexpress store now! Click me
Just place the order and leave a message saying your BLF ID before payment, our staff will modify the price for you, you need to refresh to find out!
Oh, one more thing, long tube for BLF Q8 will come out soon. :wink:
Interested
I gave someone an original SRK once. It came back a few years later with two toasted springs because someone put the cells in with alternating polarity. It should be obvious at a glance which way the cells go, given that it has all the springs on one side and a solid contact ring on the other side, but apparently that’s not enough of a hint.
Any chance to send 4 x 30Q with the Q8? I think it is legal to send to Canada if inside a flashlight.
Please follow instructions in post #1
They don’t sell 30Q. Only their own cells. They have a high drain 3000mah button top. It has gotten some good reviews. Almost the same as a 30Q in amperage. Link to the main Sofirn store.
Link to their battery store.
Good idea I was thinking the same a set of cells would be great .
I’m sure most people have found out by now, the Sofirn is for sale now at aliexpress for the discounted price, by following the instructions in the OP. For completeness I wrote an update in the OP also.
For the Amazon buyers it will take another week before the lights are there.
Ah, I’ve been checking out Amazon everyday to see if it gets listed. I guess I can chill out a while. Lol
Yeah!!
Still interested of course. Dunno if I want Amazon or Ali tho. I think I’ll go with AliExpress thanks
It worked, my C8 is ordered, thanks for the deal
It’s cool to see this light getting another round of excitement. I love the two Q8 lights I have and use them pretty often around the house and property. I sometimes turn it on and am amazed at all that power and quality for such a good price.
Question: Will the 8-cell tube just allow for extra run time or is there a bit of a power benefit?
Interested. Amazon US please.
PBW, there may well be a bit of power gain for the 8 cells simply due to the lower sag rate of 8 cells vs 4. :wink: (Guesstimating, not exactly sure that the 8 cells will be in parallel in the same manner as 4 cells.)
A bit yes, but if the springs are bypassed you are with 4 cells already running the XP-L’s near the flat bit (top) of the output curve so more current will give you more heat and not a lot of extra output.
Add 2 lights for me, Amazon DE
Mostly run time, but since it will use carriers you could adjust it to run at higher voltages. Swap the mcpcb and you could get some really high outputs.
While the temptation is there to make the Q8 have massive output, don’t do it. Bump it if you must, but the huge gains bring huge heat and makes the light almost unusable. I know, I know, but it is what it is…
Just out of curiosity: Will the long tube of the Sofirn Q8 fit with the BLF Q8? Will those 8 cells in the long tube work in parallel or in series? Thank you!
