[M4Ddeal alive] Miboxer C8 only 33 USD
Hello my dear friends!
tired of un/loading your charger multiple times to get your multi-cell powered Monsterlights ready to go?
today i have a very nice charger for you that will save you some time:
8 Slots Rapid Smart AA AAA 18650 Battery Charger
Features:
1. Compatible with:Li-ion(4.20V, 4.35V) / LiFePO4(3.60V) / Ni-MH/Ni-Cd(1.48V).
2. Suitable for different types of cylindrical rechargeable batteries.
3. Single-channel charging current up to1.5A.
4. Can set any individual channels charging current, batteries types.
5. Can set the charging current, battery type of all channels at the same time.
6. Highprecisionreferencevoltagesourcecalibration.
7. Automatically stop charging when the battery was fully charged.
8. With reverse-battery and short circuit protection function.
9. Automatically detects the battery and displays the charge status.
10. Automaticallymeasurebatteryresistance.
11. Automatically detect batteries power percentage.
12. Measure the batteries capacity by charging.
13. Supports 8-channel simultaneous independent charging without affecting each other.
14. Supports small capacity battery charging.
15. Supports lithium battery repair function.
16. Supports DC12V car charger.
17. Made of PC fire retardant materials.
18. Excellent heat dissipation design.
19. Excellent electronic circuit design.
Package Included:
1 × Battery Charger
1 × User Manual
easy enter the groupbuy:
more info:
reserved..
@M4DM4X, what happened to the number 6 line?
Absolutely no spacing at all between words.
hmm
maybe a chinese Easter egg? :D
Line6hasbeenFoy’d. :stuck_out_tongue:
Australian plug? In either way
Mine came with a European plug when I need a U.S.A. plug.
I need to get the correct charger adapter.
Every charge bay does up to 1.5a?
So 12a total if using all 8 slots???
I think it was throttled down to .8a/ch. when all 8 slots are used. I haven’t tested mine yet haha.
Please calibrate your whitespaces :sunglasses:
Can you report back, pretty please?
If you are in the U.S.A. don’t expect to receive a the correct power supply.
Here is the response from Banggood.
*Thank you for contacting us.
We checked that the accessory adapter is not included in your order 53389388. You can check the contents of this package at the link here below:https://www.banggood.com/Miboxer-C8-8-Slots-Rapid-Smart-AA-AAA-18650-Battery-Charger-Current-Optional-Overcharging-Protection-p-1332268.html?cur_warehouse=CN
it says 1.5Ax4 or 0.8Ax8 on banggood.
Even 0.8A over 8 bays is pretty good, I registered my interest.
AU plug?
Before I order I’d like to know what plug it comes with.
Is it your standard USB to small circle plug (that goes into the back of the charger)???
Edit: that’s 6.4A it’ll need, wouldn’t that need mains power?
I got one of the early ones that came with US or EU charger, from memory. Looks like you don’t get any charger atm?
Package Included:
1 × Battery Charger
1 × User Manual
Eight cells at 800mA isn’t overwhelming and the charging current step down as it analysis smartly continuously is a bit annoying. Just before my almost full Keeppower 1200mA 18350 was charging at 0.01A
So you use an power adaptor with yours?
0.01A would only be at the very end during the CV part of the charge when it’s probably already at 4.20v, correct?
Yes, got an EU adapter. Was only about 80% charged but it read around 180+mΩ resistance so the charger dropped the current right down.
So do you recommend this charger?
Maybe 3.5/5. ATM, I’m doing a lot of discharge tests with Lii-500 so use the C8 to charge. Handy to charge 4 x 1.5A but I’m sure other chargers can do that. Was useful the other day
but high resistance cells drops the current automatically, even if you set it higher it drops after a while.
