The ones from post 12 are most likely to fit the ODF30. They are fairly small diameter. At least theyāre listed dimensions show that they are small diameter. Iāve never use either of those two batteries.
Someone may have posted in this thread and then later deleted their post so the link in the email going to that particular comment was now gone.
I just recently got this from amazon 4 for $20. So far theyāre working great with my flashlights. Sc26, odl20c, m8, L2, UT02 and also works great on my olight r50.
Wolfdog not gonna lie im a little confused lol. Could you send a link to the keep powers and Shockli & orbtronics please?
I was reading the review about the Cat V6 and you all went into battery details.
Thanks. Still got them leather hands
The PLB-55 is supposedly the āCELLā that is used in all three of the batteries I mentioned. It is the best cell as far as capacity and plenty of amps[~ 20A continuous] for our flashlights.
I would definitely go w/ the Orbtonic cells over the Keeppower. It is about $4 cheaper/cell.
The link was already given for the Shockli[Mt. Elec.],I got mine elsewhere.
They will fit. HKJ has it at 66.6mm x 26.2mm. I saw a review and the guy used a Keeppower 26650 5200mAh battery.Its diameter is 26.3mm. The Efest is a much better battery. If you use HKJ comparator with the links I provided, you will see that the KP has a lot more voltage sag.
The Efest will work fine for you. Here is a place to get a pretty good price on it.
That Efest 5000 will work and is a good battery when comparing to others on HKJāS comparator and the dealers link is someone I have purchased from. They are reputable.
You can do a search on here like I did for ODF30 threads to get all the info. you need
You are not getting enough info from the SOURCE[People who have the light] because your thread title is a generalization about 26650 batteries and not specific about the ODF30.
I would get the Efest 26650 5000mAh and enjoy your light,no more worries! :sunglasses:
No, as stated earlier, the PLB-55 in all its forms are not a good choice because itās too fat at 26.7mm. There are clear warnings about itās size at MTN Electronics.
The links from HKJ require you to use the advanced post editor due to the spaces in the URL.
I donāt have much experience with Efest. Iām not sure if I trust them since the batteries under the wrapper can vary over time and their ratings are sometimes incorrect. So Iām very skeptical about that brand.
Well then he could get the Ijoy[D=26.22mm] 26650 4200mAh OR The Golisi[D=26.0mm] 26650 4300 mAh[least V sag of them all].The Shockli[D=26.0mm] 26650 4300 . That is not easy to get in the USA,especially at a good price.
The Ijoy is the most accessible of the Two. The Golisi is very expensive if you buy from a USA vape shop,would have to get it overseas!.
I checked out the Liitokala and it is also too big[D=26.8mm] according to HKJāS review.
My hometown dealer[Liionwholesale] is out of the Ijoy.
I think his best bet is the Efest, either that or pay more money or wait and buy from China.
I know this does not help the OP,I am glad that I have the Catapult V6!! NO issues with battery size and great performance
Ok everyone. I have one Efest purple and it works great in the ODF30. I wasnāt sure where to find them, but now I do thanks to Wolfdog. Never heard of mahbattery.com before.
Hmmm, HKJās specs may be a little off or maybe the cells vary. My Liitokala cyan are about 25.3-25.4 and fit the ODF30 just barely. Itās a tight air seal. The cells slide in and out slowly due to tight fit, but they do fit.
Looks like they just sold out. They were in stock on the 5th when I recommended them in post 12.
