The S10 is the ājadeā light, the T2 is the AA light
I donāt know, but sometimes the AA drivers get weird with the 14500s. I will try it first and see if I like the way it operates. Unless it is a complete bad thing (which I donāt think, coming from Simon) I will keep it on AAs. If it is not good, I may try the Li-Ions just to see how it works!
The āwarningā has been made, so now itās up to us to try them on our own
SF10 (old version, as I donāt have the new version) is nice, and the modes even on AA are good enough. Despite it, I opted to use the host and leave the driver aside! Maybe I will pick it again soon, for another thing.
*steady 225 lumen on high, fresh Eneloop. A bit lower than promised, even taking into account that it is the 4000-4500K version, but still: :+1:
*slooooow PWM on the low modes, 744 Hz, clearly Simon did not make this light for flashoholics. :person_facepalming:
*double-click for strobe engages too easy, two swift half-clicks to go from low via mid to high often results in strobe.
*nice head design with very nice deep mild OP reflector, ledboard on a shelf (so no pill) and 17mm driver behind a retaining ring. Easy to mod.
*led tint is nice and rosy.
*the light has quite a bit of throw for a light this small with OP reflector, but the center of the hotspot has some yellow.
So a solid design but the driver has to go Iām afraid. Which is a pity because I hoped for a good version of a clicky boost driver, so few around!
Some more data:
*strobe freq. 7.5 Hz
*tint in the hotspot: 3730K, exact on BBL
*CRI: 72
Size comparison with other AA clickies, Sofirn SF10,Thorfire TG06,Lumintop ToolAA,Convoy T2,Ultrafire C3,Thrunite Archer1A.
Thanks for the information on the T2 djozz! I hope it will make a good host considering some characteristics youāve mentioned !
Mine is still delayedā¦it got stuck in chinaās post office for almost a week :person_facepalming:
(i guess it was due to the Brandsā Week in AliExpress)
Thanks for the review. I was going to buy some as a host but given the slow PWM and annoying strobe, Iāll pass unless someone tells me there is a replacement driver suitable for this host. Otherwise, Iāll just get another Sofirn SF14 to swap the emitter.
@djozz
thanks for your observations on the T2.
I had hopes for more, admittedly, concerning the driver.
But nice as host, with 17mm driver and retaining ring, and I like the looks of the light.
Strobe is strange for a Convoy light, as is low PWM. Makes me think he just buys some crappy driver elsewhere. A lot of components on the spring side, though. Would be interesting to know if it uses an Attiny or a different MCU. With an Attiny we can reprogram it.
Does anyone have pictures of the driver, both sides?
Left to Right (descending in length)
Sofirn SF10 > Sofirn SF14 > Convoy T2 > Jaxman E3 > Nitefox ES10K > Lumintop Tool AA > Amutorch S3 > Sofirn SP10A > Manker E11 > DGQ Slim Ti
I like the feel of the Convoy T2, more than I expected. It was already said that the fast click to advance modes can take us to Strobe and that it as PWM on Low and Medium modes.
I chose Neutral White XPG2 and I like the tint, it is not completely white, it has some rosy and at the same time yellowish (on Low, in the hotspot). It is a very nice light, but I will mod it!
This was bought to Simon, to whom I thank for the nice work! Having a Convoy AA flashlight is quite nice and this has great quality, as ever :+1:
