Overview: All Eneloop batteries 2005-2024
Those were put on a 4 slot LiitoKala Lii-500. I had it on the 700 mah setting.
Hmm… I’ve never tried testing my Eneloop capacity on Li-500. I guess I should try it. On my Opus, none of them go above 1900 mAh.
I just passed the 100 likes on the eneloop101 facebook page. Soon I will do a giveaway, so if you want to join, go over to https://www.facebook.com/eneloop101/ and like the page..
Liked!
The giveaway has started..
Like the FB page, and join the giveaway by guessing a number between 1 and 100,000
closest number wins
I just looked at the link for Horizon Battery. They have 800 mah AAA Eneloops for $10.15/4. They also have an Ansmann AAA for $9.79/4. They are rated for 1100 mah.
Any info on that Ansmann? Seems a bit excessive.
I don't know anything to say about the Ansmann, but you could start a new thread or look for HKJs tests.
If you gonna use them 1 by 1, you should probably be okay with the Ansmann. In series I dont know how reliable they are. Eneloops are usually the same in performance and only differ very minimally. While other brands tend to have a much greater difference between batteries, so one might have less capacity and be drained deeper during discharge than the other batteries. This will only get worse the more you use them together.
Not sure if I can ask here, since this is the Eneloop thread, but I have a question about FDK/Fujitsu LSD NiMh.
I saw in local stores of 2 kinds of FDK AAA NiMh — they look similar, but one is marked HR-4UTC(2B) while another is marked HR-4UTCEX(2B).
The difference is the HR-4UTC(2B) is in Japanese (and while I can’t read Japanese, I think the numbers seem to indicate 70% capacity remain after 10 years).
The HR-4UTCEX(2B) is in English (and the card box indicates “retains 70% after 5 years”).
So it would seem the HR-4UTC(2B) is better (10 years retain 70% vs 5 years for the other), although these could just be changes in markings.
Are they from the same generation (maybe just sourced from different markets)?
The former looks the newer version with the 10 years claim. If they both cost the same and if thats a reason for deciding, I would go with the newer ones.
chibim - I looked at the table you have published. It shows for the AAA a part number of BK-4MCC A/E for both a 5 year and 10 year version. How can the correct item be identified as the newer 10 year lifetime? I am not seeing a clear differentiator when trying to buy some.
Hi alternaty, you are correct. The product number is 4mcce or 4mcca (usa) both for the older and newer one. The only way you can see it, is by looking at the 10years vs 5 years claim.
Some sellers might not even now it, and leave the original specs and product pictures of the older version online.
Just make sure you can see they have the 70% after 10 years...which by now all major stores/online stores should have anyhow, because the newest eneloops already have been on the market for 3 years.
Take care.
I know this has probably been answered else where but couldn’t quite find the answer…
What CAN’T you use these batteries for??
Can we use them in ANY device that takes AA/AAA batteries???
regards
Lohtse
They can be used in Most devices that take Alkaline batteries.
Especially in flashlights it's common to use rechargeable batteries.
Not all, there is a few low power device that requires the slightly higher voltage from unloaded alkaline.
like what Chibim?
That really depends, I personally can't remember any device in my house that can take alkaline batteries, but not rechargeable batteries. Maybe HKJ can give you some examples?
I do not have any examples, it will typically be devices that can run months or years without battery change.
I have one of those cheap fibre optic desk lamps with all the strands that won't run on eneloops. They take 3 x AAA and have no problems with alkalines. What is confusing is that they will run down the alkalines after hours and hours of continuous use, yet won't even turn on with fully charged eneloops.
What I can say is that on my Nitecore EA81 that takes 8 x AAA, the eneloops are just incredible. With alkalines, you just use turbo briefly a couple of times and then the flashlight will only go to high thereafter. With the eneloops, turbo seems to last amazingly long, maybe 5 or 10 times longer or more than the alkalines. I'm really not sure why they are that good in this particular flashlight, but they are. They may last even longer in turbo than what I am saying as I have not charged them for a long time and it is still working.
@klrman, I think you meant 8AA ;)
I also heard some older digital camera's had problems with rechargeable batteries. But these days most cameras use rechargeable lithium batteries.
Sometimes AA and AAA look the same to me when I post late at night and my mind starts getting a little fuzzy! Yes, 8 x AA for the EA81
