Test/review of Led driver 17mm 3A LiIon Fasttech 4594600
Nice indeed. Used a few of these already, now I can understand why I had a hard time trying to measure its output flicker with VISO Flicker Tester.
MOSFET temperature speaking, once the driver is installed in a flashlight it is able to transmit heat to the host, thus its effective temperature should be considerably lower ( :???: ).
Nice to see mode current can be adjusted, but I would certainly thank a more careful explanation besides what's seen in the video.
At last, let me say the driver has two track jumpers on the underside, one of them comes stock closed and the other is open:
In Chatika vas Paus photograph, the closed one is above, the open one below.
In this picture by me closed one is to the right side, open one at the left.
I wonder what do they do.
Cheers ^:)
My driver from Simon arrived with open jumpers.
I asked about this Simon. His answer: it’s useless
Let's see if I understand how current can be set for a given mode. Initial conditions:
  1. Driver has an attached load (emitter).
  2. A way to determine emitter current is set up.
  3. Driver is powered with a voltage source beefy enough to overcome all burdens.
  4. Driver has adequate cooling.
  5. Driver mode to adjust is selected.
Then, when connecting the adjustment wire to ground driver will alternatively increase or decrease current until adjustment wire is ungrounded or some limit is reached. Is this right?
I wonder how low can it go.
Cheers :-)
These look the same just rotated.
A really detailed explanation would be great!
I do not know how far you can reduce the current but i see a sens resistor. And usually playing with it, in or decreases the current. Could be a last resort if the programming is not enough.
I increased the current on my TN31 (K40m driver installed) a long time ago by switching the sense resistor from 100 or 82mOhm original to 50mOhm. And when i turned it on for the first time i was thinking : it’s alive it’s alive. Huge difference!
Hey Barkuti
have you receive your driver yet?
I’m curious to know what is the lowest current it can go.
I have 2 drivers. I think it’s highly depends on used led battery.
1,49mA with Jaxman LG led and Sanyo NCR18650GA
4,6mA with LH351D and Panasonic NCR18650B
thanks Chatika
so the driver can adjust the current for each mode?
5.6mA is true firefly and this is what im looking for :slight_smile:
Little mistake, already edited. Its 4,6mA, not 5,6.
Yes, each mode can be changed. Just select the mode in which you want to change the brightness and taptaptap (I recommend doing single/slowly taps) to reduce the current and hold for increase.
I noticed something strange. I have reduced the current of the lowest mode to about 35mA. After switching from Hi> Lo, Low it ramping from 0. It doesn’t work when turning on at lowest mode.
What does he said? :-D
Err, do you mean that, when switching from high to low, low starts ramping from 0 to your 35mA current setting? How fast?
Cheers :-)
Fast, but it can be seen. Half a second, maybe less. At 60mA, I didnt notice it.
Adjusted low mode to 100 mA and sometimes I see ramping too. Also my driver had strange modes by default: med 1.1A, high 2.2A. However, “set point” works as expected and all modes adjustable.
Barkuti, in other threads you said high mode might be bumped up via the jumper - is this the case? Did you try, and if it works - how is it?
Better try this:
All modes are independently adjustable.
Heatsink the driver well.
Cheers :-)
How do I set the Mod I plan to change? By On/off the power source and leaving the driver memorized the mode?
And does the Simon ´s method works on new drivers from Fasttech?
You need to chose mode that you want to change. And tap, tap, tap or hoooold.
Yes, its works.
Yeah, definitely !
Thanks!
I didn’t think it would work with the new version.
This seems to be normal.
Mine do this too, even with stock settings.
So, can the current of the high mode be adjusted to values higher than 3 Amperes? Or is 3 Amperes the maximum?
