I thought this was known. Due to the unique battery tube length and design, you have a smaller than normal range of batteries that fit. Maybe we will need to see if the latest prototype can fit them to give confirmation.
Like I said. It may not be confirmed. Maybe a particular short protected cell will fit? ToyKeeper will have to say for sure. I’ve just always thought it was unprotected only.
@Toykeeper
You asked for a diffuser a time ago.
And there was a recommendation from the german Taschenlampen-Forum.
Did you get that one and does it fit?
The NFD25 is flat, designed to spread out the beam. So, not the right category of product.
The NDF25 is a cone, and it technically fits, but it’s not a good fit and not very useful as a diffuser cone either. It’s basically transparent, doesn’t emit light very evenly, and does weird things to the tint.
There’s also a stretchy silicone one, but it’s difficult to put on, it isn’t opaque enough, and it looks awkwardly like a stubby condom.
So I’m still looking for a diffuser cone which fits well and is opaque.
Well, true, if you can flash it into those lights!…
The FW3A will be the first light I will have with that FW installed, and as far as I perceived, it will be the first light with Anduril as stock FW, so it makes it different!
Besides that, the elegance of this flasglight makes it look better as a candle But that is just a preference
FWIW, a tail button is a bit of a drawback for candle use, because it means picking up the light to press the button. Otherwise though, the FW3A should work nicely as a candle.
