It will have all the parts you need to convert your existing BLF GT to a Giggle Monster, Including
12v drop in replacement DTP copper MCPCB
XHP70.2 LED reflowed to the mcpcb
Centering ring
12V Texas Avenger V2 driver
To install the kit you will need to be able to open your GT first (easier said then done in some cases), un-solder 2 wires and then solder 2 more wires to the new mcpcb. When soldering to the mcpcb you will need to turn your iron as hot as it will go in order to get the solder to stick, soldering to mcpcb’s can be difficult depending on the quality of your iron. Soldering is required to install this kit, you have been warned.
Notice: The GT head is VERY VERY tight, make sure you can open your light before ordering. Many people report not being to open their light without damage.
Ordered NW BLF GT70, NW conversion kit, and a set of battery carriers.
MANY thanks to all of those involved especially Mr. Texas Ace for all of his time getting Lumintop to sell the conversion kits.
I hope that everyone remembers that these new battery carriers require unprotected button top cells. I modified the first couple of posts a couple days ago to reflect this new development.
The website still says protected cells are recommended, but this is incorrect.
Hi,
I registered interest for 2 cell carriers, but not for the conversion kit.
With the cell carriers not being available, can I use the conversion kit GB instead?
