Just ordered the CW conversion kit, got my razor ready to slice dome it! thanks.
Just ordered the Cool White conversion kit as well! Leaving it as is, dome and all. Cant wait to install and test it out in one of my GT’s!
Hi,
I registered interest for 2 cell carriers, but not for the conversion kit.
With the cell carriers not being available, can I use the conversion kit GB instead?
Ok im a bit confused.
The way it looks on the order page for the conversion kit, it seems to suggest the updated battery carriers are included with the kit.
Is this true?
Or do i need to order the carriers in a separate order and THEN the kit in a separate order ?
Do a seperate order for each item. Carriers are not part of the Conversion Kits.
The cell carriers are available. Yes you can do that if you wish or get both if you wish. :+1:
Then why do it say it…?
GT70 Conversion Kits are for GT70 DIY.
1*XHP70.2 LED, Cold white or Neutral white options
1*Centering Ring
1*TA Driver Giggle Monster
2*Cell carriers
^exactly. I know originally the carriers were not included, but the order page is confusing.
teacher: VernonDent:Ok im a bit confused.
Is this true?
1*Centering Ring
2*Cell carriers
Good question. . But I would not attempt to answer it on a bet…
Yep… it does take a bit of ’reading between the lines’ to decipher it.
Just keep in mind the blf gt is very difficult to open and shaving the xhp70.2 will result in green tint…
I ordered only the conversion kit because the coupon does not work with the cell carriers, not even in separate orders.
When the cell carriers are at the offered price I will buy them.
Cell carriers - 1x for $15 2x for $28 (unprotected cells only)
Is this true?
1*Centering Ring
2*Cell carriers
They appear to be selling 3 different items on this one page.
1. CW conversion kit
2. NW conversion kit
3. Carriers x 2
Team-Giggle_Monster:Cell carriers - 1x for $15 2x for $28 (unprotected cells only)
Hmmmm…. that is strange. It worked for me. The Code knocked $20 off the price of the carriers…… making them $28 for a set of two.
Oh yeah, it seems they are just sold in pairs… no singles.
I think TA will need to ask them why the coupon is not working for the carriers. Lumintop may not even be aware of the problem. It seems clearing cookies got it working.
It seems they have several glitches in their website. It might take a day or so for them to get it all working smoothly.
Unloco:I ordered only the conversion kit because the coupon does not work with the cell carriers, not even in separate orders.
I deleted the cookies and… it worked!
Thanks!
3. Carriers x 2
Yes… that would be correct. And only 1 item per order for the discount code to work properly for each item.
It is a puzzle that works great…. when it is figured out.
The Discount Code is working for the Battery Carriers Jason.
teacher: Unloco:I ordered only the conversion kit because the coupon does not work with the cell carriers, not even in separate orders.
Thanks!
Excellent, glad it worked out!! Your welcome…… :+1:
Slicing the NW led might very well have some green in it since it is a tint code C. The B and C leds are towards the green side of the Black Body Locus (BBL).
The CW is right on top of the BBL, so it probably won’t have much green or pink in it. It should have a more neutral tint, not to be confused with the neutral white color temperature.
