Ok thanks for the info. I was planning on dedoming and thus was originally wanting CW, but I’m thinking the domed version throws far enough, and I really love the tint on my Q8 which is close to 4500-5000k from what I remember. So I may end up ordering NW.
After a couple of weeks with my GT70, I can say that I’m 99% happy with this monster. The minus 1% is due to the lanyard holes do not line up. Not the end of the world. It is heavy and I need to get a shoulder strap for it. Any recommendations?
The tailcap should spin to allow the holes to line up. A few said that there was a burr on it that needed to be cleaned off. You can remove it from the inside with a pair of needle nose pliers. the center section unscrews from the outside.
just what I noticed in the GT mini and also seen on the GT conversion kit
Fake Atmel MCU from some chineese distributor
the original BLF GT driver had the orighinal Atmel chips, but someone decided to safe 30 cents or so and sourced fakes
GT mini vs original GT XHP35
it also uses a voltage divider to detect battery voltage, so likely code changes needed to get it work so it cant be just a mistake ordering from wrong source
The website loads slow, and when it loads i can not select anything or add anything. (the buttons stay grayed out) here is their website as seen in the photo below. (just a blank page with no images or script) I tried two different computers and different browsers, ( chrome & firefox) nothing works.
My guess from working with china is not that they so much tried to save a little money but that the supplier sold them fakes as the real thing. China companies rip off other china companies just as readily as anyone else.
Tried two different computers, two different browsers, and two different ISP connections. its near impossible for them all to have the same exact issue. See my post above #1778.
