@Toykeeper
You asked for a diffuser a time ago.
And there was a recommendation from the german Taschenlampen-Forum.
Did you get that one and does it fit?
Quote:
Der Nitecore NFD25 ist für Lampen mit 25,4mm Kopf…
The NFD25 is flat, designed to spread out the beam. So, not the right category of product.
The NDF25 is a cone, and it technically fits, but it’s not a good fit and not very useful as a diffuser cone either. It’s basically transparent, doesn’t emit light very evenly, and does weird things to the tint.
There’s also a stretchy silicone one, but it’s difficult to put on, it isn’t opaque enough, and it looks awkwardly like a stubby condom.
So I’m still looking for a diffuser cone which fits well and is opaque.
We already have the world’s best candle, the D4, D4S, or any other tail standing light that can run Anduril.
Well, true, if you can flash it into those lights!…
The FW3A will be the first light I will have with that FW installed, and as far as I perceived, it will be the first light with Anduril as stock FW, so it makes it different!
Besides that, the elegance of this flasglight makes it look better as a candle But that is just a preference
FWIW, a tail button is a bit of a drawback for candle use, because it means picking up the light to press the button. Otherwise though, the FW3A should work nicely as a candle.
I thought about what you’re saying and as long as it tailstands,I guess it wont be a big issue
Sometimes I use the Convoys to a similar function (bedside standing) and it works fine!
So, as long as the tail allows it to stand, it won’t bug me much!
Apologies, I’m sorry.
Bob_McBob is #1038 and #1142,
Bob_McBob has requested three Flashlights “3”
Moparguy is #1278, #1279, #1280 and #1281,
Moparguy only asked for two flashlights, (request two flashlights) “2”. see: Post # 3547
Moparguy wrote:
Please sign me up for 2 ea. FW3A flashlights.
Dadpool is #385 and #1331, Dadpool only asked for a flashlight, (ask for a flashlight) “1”. see:
Dadpool wrote:
Post #710 Please add me to the list for 1 light. Thanks!
Dadpool wrote:
Post #3893 Thought I’d signed up already, but just in case I’m signing up now!
Also voted in both polls. This looks like it’s going to be a great light.
# Post I must apologise profusely, I asked for two of these in post number 1574, I completely forgot I’d already asked for one a few months earlier in post number 889.
Could I be a pain and just have two instead of three please? Again, I apologise. Got a bit overexcited possibly!
. New requests: Already updated by TK on Post # 4, page 1
1478 – # Post . nsk1979
1479 – # Post . derivepower
1480 – # Post . lexvegas
1481 – # Post . Tejasandre
1482 – # Post . Tejasandre
1483 – # Post . velocraig
1484 – # Post . Tech25
1485 – # Post . donnakebab
1486 – # Post . donnakebab
1487 – # Post . ansb29
1488 – # Post . ansb29
1489 – # Post . ansb29
1490 – # Post . caplang
1491 – # Post . hanoilighting208
1492 – # Post . huey18 1493 – # Post . lew123
1494 – # Post . Eggun
1495 – # Post . D4rka2nx
1496 – # Post . Marnav1
1497 – # Post . superbob47
1498 – # Post . scottyhazzard
1499 – # Post . pfn
1500 – # Post . MikeMacD
1501 – # Post . MikeMacD
1502 – # Post . Sillen
1503 – # Post . Hexlord
. New requests: Not updated in Post #4 page 1.
1504 – # Post . scalyman.
1505 – # Post . LGW
1506 – # Post . gottobegeek
1507 – # Post . sergey—neo
1508 – # Post . Nichia
1509 – # Post . Juls Boo
1510 – # Post . Jaded
1511 – # Post . idleprocess
1512 – # Post . idleprocess
1513 – # Post . zapviii
1514 – # Post . gottawearshades
1515 – # Post odriewniffe
1516 – # Post . adam7027
1517 – # Post . adam7027
1518 – # Post . adam7027
1519 – # Post . WhitedragonBC
1520 – # Post . gtv4
1521 – # Post . theRealSammyG
1522 – # Post . theRealSammyG
1523 – # Post . Fiiish
1524 – # Post . lachesis
1525 – # Post . lachesis
1526 – # Post . Unloco
1527 – # Post . Unloco
1260 – # Post . manithree : Delete
1528 – # Post . mgracia85
1529 – # Post . jimmymke
1530 – # Post . McLight
1531 – # Post . gman7228
1532 – # Post . BadWolf
1533 –
1534 –
1535 –
1536 –
1537 –
1538 –
1539 –
1540 –
1541 –
1542 –
1543 –
1544 –
1545 –
1546 –
1547 –
1548 –
1549 –
1550 –
. – - , NOTE: If I overlooked a post, PLEASE IM me and i’ll edit for correction.
. In upgrade . . . In upgrade . . . In upgrade . . . In upgrade . . . In upgrade
I guess they do. Still, with a diffuser, these will be equally great.
Just to clarify, those lights use RampingIOS or D4 ramping, so no candle mode.
They can be reflashed to use Anduril though, which will give them candle mode.
Accurate clarification, that is what I was trying to say. As far as the diffuser goes, same for the D4 and this light, you likely need to roll your own.
I have the D4 with Anduril, and it does make for a great candle, even without the diffuser.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
Why is it a deal breaker for you? As long as the driver has LVP is there any point having protected cells? Or do you like the added protection of having it on the cell as well as the driver?
Just about all of my 18650 cells are protected, and the couple that are unprotected aren't all that great.
I guess I could invest in some quality unprotected cells, though I do not particularly want to.
Just about all of my 18650 cells are protected, and the couple that are unprotected aren’t all that great.
Member for 8+ years and almost 11,000 posts…and no decent high drain unprotected cells?
My mind is blown!
…. That makes two of us….. I was thinking the same thing….
Wow – I don’t have ANY protected cells, and don’t want them either.
I don’t want issues with who made the circuit, how it performs, whether it will fit, metal strip running down the side – yuk.
I have a few Panny B’s for capacity and the rest are nearly all 30Q’s button or flat top, aside from a few laptop pulls, and some 14500/10440 of mixed breed.
Hitherto I bought mostly protected cells, as I got more knowledge about Li-ion cells, I will buy mostly unprotected. Think about Tesla, thousands of unprotected cells under your ass, still no spontaneously fire incidents.
Those are still protected, just through a BMS or battery management system. Still, there is the rare fire usually due to the battery pack being punctured. Way way more safer than gasoline, though. Even a protected 18650 can burn up if the protection circuit is in the negative end and the positive metal strap along the side gets scratched and causes a short in the battery tube.
I still use protected cells in headlamps and the lights that I give away, even if the light has lvp built in.
Texas Ace Lumen Tube calibrated with Maukka lights
I’m hoping Fireflies updates future batches of the ROT66 to Anduril. If so, then FW3A would be the 2nd.
For the ultimate candle effect, instead of a slip-on diffuser, you’ll want to set it on a small fan, with orange and/or yellow tissue paper taped to the top to “flicker” in the breeze like this sort of gadget:
Unprotected only. The front and back half can’t screw together far enough to work when a protected cell is used.
It would be the world’s best candle.
Sorry
(but not with those silicone-almost-condom-like diffusers :p)
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
Do those have candle mode?
Any update on when production will start. I’m really itching for this light.
Thu, 05/04/2017 – 04:50
first post that I see about this chimera
That’s what I thought to be honest. As long as the flashlight itself has LVP, surely it’s ok.
I just wanted to add to this, thank you very much Toykeeper!
GIVEAWAY: 1
GIVEAWAY: 1
Una por favor Pepinfaxera,solo una
Gracias
Click this to go to signature links.
The FW3A will have it as ‘standard equipment’.
.................................. "Slow is Smooth, Smooth is Fast" ...................................
Texas Lumens Flashlights / M4D M4X Deals : sign up - save $$$$
Rudeness Level _ mΩ _ {width:70%} _ LightWiki _ LED Tint Chart
Xlamp size chart _ BatteryU _ Flashaholic? Need Professional Help??? TheOriginal _ TAB _ LightSearch _ BatterySearch _ 14500's _ DiCal
31 knives for sale=USA only ☮♫☯
[WTS] Brand New Timex Expedition Vibe Shock Camo Watch [USA Only]
My mind is blown!
Interested in one, thank you
Let a flooder be my wife and a thrower be my mistress
Beam me up!
I have some protected cell from when I first started with LiIon & was afraid I’d blow myself up.
. But since then I have gone mostly to unprotected.
Please add me to the list with 1 light. Thanks!
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
You’ve heard of the Fisker Karma? Atleast tesla makes their packs water proof lol
RIP SPC Joey Riley, KIA 11/24/14. Now I am become death, the destroyer of worlds.
