The BLF GT70 "Giggle Monster" is here! 7,500lumens, 1,500m throw! Group buy Closed!
Thanks TA for the nearly instantaneous response. NW+accessories successfully ordered. Now the most difficult aspect, waiting!
There is a full breakdown of the tailcap with pictures in this link. Unfortunately, I can’t copy the post here.
Good job, I knew that existed but had no idea where to start looking for it.
Just use it as a spare carriers, or in the future, some machine shop will make a coupler which you can run 12 cells.
Vinh at Skylumen already has adapters available.
Hmmm, is the Canadian government tampering with your internet access? Lol
So the website loads up fine? (I guess that’s the problem)
Can you choose the item you want to buy? If so, do the light blue buttons turn dark blue?
just what I noticed in the GT mini and also seen on the GT conversion kit
Fake Atmel MCU from some chineese distributor
the original BLF GT driver had the orighinal Atmel chips, but someone decided to safe 30 cents or so and sourced fakes
GT mini vs original GT XHP35
it also uses a voltage divider to detect battery voltage, so likely code changes needed to get it work so it cant be just a mistake ordering from wrong source
You are having a very strange issue. It works just fine for me.
Firstly I would clear all cache and cookies.
Next try starting your browser with add-on’s disabled (in firefox it is in the help menu).
If that doesn’t work then it would seem to be something with your ISP or DNS settings would be my next guess.
Try flushing your DNS by running :
ipconfig /flushdns
from the windows command prompt.
If that still doesn’t work do you have access to any other internet providers at work, friends house, library ect?
Can you access the plain lumintop site? : http://www.lumintoponline.com/
The website loads slow, and when it loads i can not select anything or add anything. (the buttons stay grayed out) here is their website as seen in the photo below. (just a blank page with no images or script) I tried two different computers and different browsers, ( chrome & firefox) nothing works.
Lumintop is selling these with fake ( or knock-off) chips instead of the real Atmel chips?
My guess from working with china is not that they so much tried to save a little money but that the supplier sold them fakes as the real thing. China companies rip off other china companies just as readily as anyone else.
Tried two different computers, two different browsers, and two different ISP connections. its near impossible for them all to have the same exact issue. See my post above #1778.
That does look like some kind of local issue, could be your ISP’s local cache is the problem or who knows what. It is very strange you are the only one reporting the issue though.
And for the record, the lights will not be shipping for at least a weeks, most likely 2 weeks, so there is no major rush.
I would try the things I listed above and see what happens.
I highly doubt that they know they are fake, unlike some manufactures lumintop has never complained about the cost of components for their lights, they will simply pay what is needed to get what is needed to make it work. Except in cases where they simply can not source the components at all.
They appear to work fine though, so it is possible that they are “real” but made “off-the-record” which is another common Chinese trick when making products for overseas companies. I am not going to speculate as long as they do the job though.
Fake uses a voltage divider to detect battery voltage on Pin 7 from what I measured with DMM 0.7V and 2 resistors
I removed one of them and it works not sure why the voltage divider is there it increases parasitic drain
Have you cleared your cache and cookies?
Run the browser with add-on’s disabled?
Flushed your DNS cache?
I did not see these things mentioned before and could effect 2 separate computers if they were used to access the lumintop site before they updated it.
Also can you access the base site? http://www.lumintoponline.com/
I don’t understand what this has to do with the MCU?
That is simply how the firmware is setup, to detect the voltage with a voltage divider. They copied the TA drivers that used a voltage divider.
That is just a design choice, not a problem or an indication of an issue.
some MCUs need a external divider, this one not as I tested it without resistor
but still bad move to go to some cheap chineese distributor, its not that hard to see it is not original
As I said, I don’t think they did go with a “cheap chineese distributor”. That is not what they have shown to do in the past, even with some really expensive parts we worked with on another project.
It is very hard for them to see it is not original if they do not have one to compare and the one they get works as it should. I doubt they even see the components before the drivers are delivered. Most of the time the assembly house sources these things and then just delivers the final drivers.
Just ask anyone here to look at a chip by eye with nothing of reference and tell if it is a fake, same thing with lumintop. Heck I could not tell it is a fake without them side by side.
On top of all that, if it does what it is supposed to do, why would they even look? They would just assume that the parts delivered were the parts they ordered. I bet if I looked at the prototype drivers they sent me they would have the same MCU, I didn’t even notice because the MCU worked as intended so why assume that it was not the right one?
While it is not ideal, it works and has not had any issues. Lots of possible explanations, could even just be old stock from 10 years ago with different markings for all we know.
Lastly that is a GT-mini driver, not a GT70 driver. So isn’t this the wrong thread anyways?
I discovered my ISP is blocking their site because it says its an un-secure site.
