The BLF GT70 "Giggle Monster" is here! 7,500lumens, 1,500m throw! Group buy Closed!
That does look like some kind of local issue, could be your ISP’s local cache is the problem or who knows what. It is very strange you are the only one reporting the issue though.
And for the record, the lights will not be shipping for at least a weeks, most likely 2 weeks, so there is no major rush.
I would try the things I listed above and see what happens.
I highly doubt that they know they are fake, unlike some manufactures lumintop has never complained about the cost of components for their lights, they will simply pay what is needed to get what is needed to make it work. Except in cases where they simply can not source the components at all.
They appear to work fine though, so it is possible that they are “real” but made “off-the-record” which is another common Chinese trick when making products for overseas companies. I am not going to speculate as long as they do the job though.
Fake uses a voltage divider to detect battery voltage on Pin 7 from what I measured with DMM 0.7V and 2 resistors
I removed one of them and it works not sure why the voltage divider is there it increases parasitic drain
Have you cleared your cache and cookies?
Run the browser with add-on’s disabled?
Flushed your DNS cache?
I did not see these things mentioned before and could effect 2 separate computers if they were used to access the lumintop site before they updated it.
Also can you access the base site? http://www.lumintoponline.com/
I don’t understand what this has to do with the MCU?
That is simply how the firmware is setup, to detect the voltage with a voltage divider. They copied the TA drivers that used a voltage divider.
That is just a design choice, not a problem or an indication of an issue.
some MCUs need a external divider, this one not as I tested it without resistor
but still bad move to go to some cheap chineese distributor, its not that hard to see it is not original
As I said, I don’t think they did go with a “cheap chineese distributor”. That is not what they have shown to do in the past, even with some really expensive parts we worked with on another project.
It is very hard for them to see it is not original if they do not have one to compare and the one they get works as it should. I doubt they even see the components before the drivers are delivered. Most of the time the assembly house sources these things and then just delivers the final drivers.
Just ask anyone here to look at a chip by eye with nothing of reference and tell if it is a fake, same thing with lumintop. Heck I could not tell it is a fake without them side by side.
On top of all that, if it does what it is supposed to do, why would they even look? They would just assume that the parts delivered were the parts they ordered. I bet if I looked at the prototype drivers they sent me they would have the same MCU, I didn’t even notice because the MCU worked as intended so why assume that it was not the right one?
While it is not ideal, it works and has not had any issues. Lots of possible explanations, could even just be old stock from 10 years ago with different markings for all we know.
Lastly that is a GT-mini driver, not a GT70 driver. So isn’t this the wrong thread anyways?
I discovered my ISP is blocking their site because it says its an un-secure site.
Yep, that would explain it.
Maybe go to a starbucks or library to use the internet there?
ok, i logged into the internet using my phone & cell carrier to get it to work. Just curious, is the short tube still available for the GT, and will the conversion GT70 kit still work with a the single battery carrier in the short tube with the GT70 kit? ( not sure if i missed the info on that mentioned before as this tread is huge.
I used my phone hot-spot to get the site to load. :slight_smile:
The short tube should be available, I will see if it is out of stock. If it is out of stock you can order it later.
The GT70 will work with 4 cells but the output will be less of course.
Even the marking has a spelling error
its always been a 20SU code for size and while the fake shows 20U
and there is no MCU that has not the triangle on it
if you google for attiny85-20U we land here
https://shopee.tw/78933626-i.78933626.1368210563
Fireflies had the excact same fake MCU from a chineese distributor and huge programming issues with it
receiving prototypes with it I was also not able to flash it
all Atmel MCUs even the cheap 13A have always markings on the back side
I had completely forgot to order the short tube when it came available as i was going through a family disaster and away out of town during that time i believe, so i missed it. >.<
Seeing as I did not even notice that they were fake since they worked fine and I had no issues, I sure as heck can’t blame them for the same thing.
They do the job, that is all that matters. They also work with the normal Tiny85 Narsil Firmware I sent them. So I am not complaining.
Plus the more I learn about how things really work in China, the more I understand how things like this can happen even with the best of intentions.
Looks like I didn’t receive the NW email. Can someone send me the info?
Sent
Same here, I didn’t receive the info email for the NW BLF GT70.
Please send me the info.
Sent
I ordered a NW kit, too bad I entered my address incorrectly. Not sure if I did it or the website glitched. It ended up being a mix of my billing and shipping addresses. I contacted Lumintop via their message feature with the correct address. I hope it makes it to me lol.
