There’s not much to be gained by bypassing Emisar springs. They were chosen to make that less relevant, by being low-resistance and compressing pretty much flat during use.
Don’t forget you are talking to a forum of powerhungry flashlight enthusiasts. :laughing: These springs have about 8 mOhms each. Cutting out nearly 16 mOhms would significantly reduce the total circuit resistance and would get some gains. But I think the design is an ok trade-off to get the smaller size.
I modded a friends S41, changed emitters to the W6 binned Samsung LH351D at 5000K, swapped the MOSFET for an Vishay-Dale SIR404DP, changed leads to 20ga Teflon coated, 22ga spring bypasses… with a new Nitecore 18350 it does 3232 lumens, on a Samsung 25S it pushes 4888 lumens!
I advised him on getting a pair of oven mitts to wear…
At a 20mV Vdroop at 6A, these springs have 3,33mOhm of resistance.
It’s absolutely amazing for a spring. Even mine are 10mOhm BeCu springs are nothing compared to them. Doing a spring bypass would just help lower resistance even further, but you will not get much in terms of % brightness boost, with a ton more heat.
Remember though Blue, all things are a matter of perspective. If it’s not JUST the spring that is being changed, it may be an open doorway to another dimension. For example, what seems like a small gain on an emitter that is maxed out, swap to an emitter that can handle double or triple the current and suddenly that small gain becomes much larger. An example would be removing the current limited XM-L2 U4 and putting an SST-40 in it’s place. Or using an SBT-70 that can gobble up 20A all by itself… same 3V supply demand.
How did you measure the springs? Pressed nearly flat against the bare pad at the center of the tail/driver PCB? If not then you may know the resistance of the springs, but you don’t understand the system.
@BlueSwordM
Yes the SBT-70 was a power drainer. Factory rating Vf 3,8V /10,5A. But could handle much more with propper cooling. And because of the round die perfect for Aspherics. I think it still has one of the nicest beam profiles in an aspheric light. I tryed to buy one when i really started with modding. But they were gone at that time.
The CBT-140 is still in the wild, big price to go with it’s big output numbers though. Probably the last round die, at least in “white”. There are SBT-70’s in green and blue.
In a Jaxman Z1, quality zoomie…
This was using a pre-focus aspheric that I built a holder for and had threaded in directly on top of the emitter.
I had also built a new solid copper pill to replace the brass one that came in the light.
Removed the glass window over the die as well, somehow I just love seeing that bridgework of 24 bond wires out in the open, in all it’s glory.
Love it so much I once took a stacked focus shot in macro to be able to see it clearly. lol
Edit: guess I have to spell it out…Pink Panda quoted me and commented on what I said, then stated “Be interested in seeing your attempt at masking Enderman”
You are right, the resistance might go down when the spring is compressed. But maybe not by much since the spring doesn’t really touch itself upon compressing and the center shouldn’t actually touch the PCB.
The body tube on my D4s is ~70mm. My cell is 65mm long. That leaves 2.5mm for each spring. The spring wire is 1mm in diameter. I have a few extra Emisar springs I bought. When compressed to 2.5mm the electrical path isn’t the full spring length. There is contact between coils and it looks like there is more than one loop in contact at the battery end. It is a little hard to estimate the shortest path, though.
It looks to me like some tweaking the roundness and/or alignment of the coils could actually lead to better contact, by forcing the coils to slip against eachother as they are compressed and/or tipping a bit so that there are additional contacts and paths between spring, battery, and pcb.
Tool is finnished so i do not scratch the head, lether cushions for the vise are glued together and cured and the new driver (from Lexel) is ready. So time to pop the H03 open. Have to get the heatgun ready first but then nothing will stop me. Wish me luck. Hope to get it open without doing any damage to the threads. Switch rubber and front glass/tir are removed. Tube is filled with a 19,5mm pipe to prevent it from squashing. I think there is nothing else i can do to prevent failure.
