Yep, for those in the USA MTN always has some good LED’s as well and you can add some other flashlight stuff to the order while you are there along with supporting the BLF family.
Awww crap. Paid full price for the spare carrier. Oh well. I think they deserve a little something for all the hard work. Can’t wait! Wait… how long is shipping to California?
They are supposed to get the LED’s in late this week or early next week is the last I was told. Once that happens they have to get them reflowed to the mcpcb’s and then they can start packing orders. I would guess they will start shipping in 2-3 weeks.
Once shipped it generally only takes a few days for DHL to deliver to the USA.
Received the email saying the NW conversion kits are ready. The website allows me to order the CW kit as well… are those ready? The email didn’t explicitly say so I just want to double check :+1:
what is the expected run time in hi with the conversion kit?
can you use the short tube and long tube together to create a 3S carrier for more run time?
Top of the ramp might be relatively stable for a while but I wouldn’t say for certain how bright that is. I’ve got my 8 30Q cells charging so will see what the go is using the ceiling bounce app with the light tailstanding inside a 22°C room with a fan oscilating.
I got about half the output number as turbo at the top of the ramp and it ran like so. The sag may have been part heat, part cells to attirbute to the decline in output over the 10 minutes.
I left it untouched pointing at the ceiling in a 22°C air conditioned room with a fan oscilating 2m away. I checked the temp 3 times and it never got hot to the point I was worried about it. I just wanted to go light some trees up from my balcony which are a few hundred metres away (~300m)
Turbo would have got much hotter, sagged much faster and definitely would not have got to 10 minutes in-hand-use in warmer climates like Australia most of the year as it would just be too hot to hold.
EDIT: I forgot to mention the jumps in output is another light source being picked up by the phone too if anyone is wondering why the light increased for a little while. That was when I came back into the room to check temp and stuff around. I’m not sure why it started to climb after the last spike up until I stopped logging…
You are correct that the top of the ramp is about 50-60% of the output as turbo and it is set that way for various reasons. One of which is that at this level it can sustain the output for an extended time, where you are correct, turbo will indeed trigger thermal protection in a few minutes and have a much more drastic drop in lumens. That is why turbo is only for limited bursts.
Got the Mail - Firefox does not work but IE worked .
Yesterday i ordered three times one CW conversion kit and two carriers .
Now its time to wait …….
Thank You guys ……. M.
