You have to define what driver you are refering to.
Basically yes. If you need specifics on how to add lights to your L6 I show the process in my signature lights. Lexels latest drivers for the L6 have 2 ways to run the lights. Constant or MCU controlled.
No, pretty much all drivers have at least one MCU controlled LED pinout (1S 3 Channel, 2S 2 Channel)
on most recent drivers I have also one pin with a resistor to vcc or 5V LDO added, so both Switch LED channels can be simply soldered to a pad and have a resistor on the driver
L MCU controlled LED (over a resistor)
LS battery or 5V (depending where the resistor is soldered and if its 1 or 2S driver)
S switch
G common ground
on the switch board there are 2 indipendant LED positive pads you can route to L and LS as you like
I also added boards with 2 LEds in series for 2S drivers so the standby current of the LEDs can be cut in half for types with forward voltage below 2.2V
Okay, this is why I ask since there are many drivers that can fit the L6.
The stock FX-30 driver has no proper output for side switch lights. On this one you have to power your switch lights from a constant power source such as the positive lead going to the LED. You also have to make sure to add a resistor to reduce the voltage. The switch light will turn on and off with the tail switch. Look at my L6 and Mini L6 links to see how I wired them. It is not too hard.
Looking to order a couple drivers for my H03 please. With temp and lvp precalibrated. And I guess the short springs? Whichever spring is most commonly ordered with this driver, it’s my first time.
Hi Lexel,
I’m not sure if this was long ago asked, do you have a 21mm driver planned for use in the Sofirn C8F 21700 version? So e-switch, Narsil (Anduril?), FET+7135, no components at battery side because of thick retaining ring. A nasty feature of this host is that the rim on which the driver rests is rather wide, more than a mm (I can measure the exact width if needed), so the components should not be much further to the side than a 17mm driver.
If you can make this, I’m interested!
I ordered a 20mm e-switch driver from him for the 21700 C8F host. Not sure if it shipped yet or not but I guess we will see how it fits or what mods I need to make to get it to work when it arrives.
For C8F with 21700 I need excact measurements for the driver to make a new design, could be basically a modified 17mm one
I hope Sofirn does at least modified the head so the MCPCB gets screwed on the head, got always shorting issues with the original design as often the head cut in the wires or if not screwed on the reflector shorting to reflector
20mm might work, I can sand it bigger after cutting out from a 10x10cm board so its 21mm but copper only 20mm wide
not sure if the silkscreen of the 20mm will be a problem with the retaining ring
I have downloaded Anduril a while ago but never come to really use it as it was mostly a problem to get it work with Atmel Studio
Today I tried to download the BLF GT Anduril Hex but not found on server
