This is common as well. There are different charge rates for every battery depending on whether you want max life or not. The capacity is going to slowly be reduced everytime you recharge it anyway, some charge rates reduce it a bit quicker than others.
21700 flashlights are slowly coming out. Most are pretty expensive though. I just bought the Sofirn C8F 21700 for $36 shipped including a 4000mah battery and a simple charger. I think this is the cheapest 21700 light I’ve seen so far.
To clarify, I was refering to flashlight users such as all of us here. We don’t monitor battery temps in flashlights (unless we need to).
I’m sure these new higher ratings the manufacturers are using are more for vehicle use where they are water cooled and monitored closely. Or tool use or vacuum use etc… where temperatures can at least be monitored.
We are just low-tech bums. We have to take the battery out of our flashlight and measure the temperature by hand and go “Ewww boy, that sure feels hot!”. Lol
A modern high capacity battery is never going to match the output of a high current battery. The manufacturers are able to tweak their chemical mix to either maximize capacity or current or anywhere in between. This is why the 30T has the highest current, but the lowest capacity and the 50E has the highest capacity but lowest current. Then the 40T is right in the middle between current and capacity.
(I’m talking about continuous current ratings like HKJ and Mooch use)
The reason I said that[10A only] is because Hydraxx said the 50T[50E?] is replacing the 40T. So one would assume it would be an Upgrade in capacity and output,at least that is how I would interpret it.
No, I did say 50G, the 50E it, is a different version, with a different chemistry and a different life because it is originally intended for the electric vehicle industry specifically, the first versions of test ( TestBuild in Samsung jargon) with an inscription “EV21700-50G” on the cell, “EV” as you would guess for “Electric Vehicle”. And indeed you will find little reference to 50G because initially they were sold almost exclusively in closed market (reserved for professionals and industry), the only ones to my knowledge to have obtained a significant amount of these cells 50G is VapCell and still it did not last, they quickly replaced by LG M50 in their “VapCell Purple 21700 5000mAh 10A”: the first versions sold were Samsung 50G then once their stock of 50G exhausted, they passed on LG M50s that are equivalent in terms of performance (although the capacity of the M50 is a little better in practice of about 50-100mAh).
Treat me as a liar, it will be more direct and less cowardly on your part, seriously, I would win what to lie to you, for proof: A big French company of the energy field lists in its data the Samsung INR21700-50G: https: // www.arts-energy.com/fr/solutions/accumulateurs-li-ion/gamme-li-ion-power/, it’s still a crazy thing on this forum, as soon as we say something that other users do not know and we are recently registered on this forum, we are considered a liar, I am getting a little tired of proving my good faith, do I treat you as a liar or even I sub- hear, yet I do not know you?
Calmly, we’re all here to share our knowledge and debate, that’s how a community learns and evolves, not pulling around and being suspicious of each other.
I received my battery order from 18650batterystore.com and took capacity measurements with my Xtar VP4 Plus Dragon charger:
Samsung 21700 30T (not rewrap) : 3,171 mah
Efest 21700 5000mah: 5,035 mah (Mooch said it’s probably an LG M50 inside)
QSO Samsung 21700 40T (red wrapper): 4,091, 4,013 mah
Vapcell 21700 40T (gold color wrapper): 4,038 mah
Vapcell 21700 VTC6A (black color wrapper): 4,186 mah (This one has the QR code square at the bottom. Mooch said the older versions do not have it and have slightly less capacity)
QSO Sony 21700 VTC6A (black color wrapper): 4,055, 4,022 mah (This one is odd because the charge capacity are 4,2xx, which is 200mah higher than the measured discharge capacity. Usually the charge and discharge capacity are very close within 50mah. Mooch got 4,1xx mah on the samples from the same store. This also has the QR code. Maybe my charger terminated the discharge a little too soon on these)
I think the VTC6A might be a slightly better battery than the 40T just like the VTC6 is better than the 30Q. Mooch rates the VTC6A at 30A continuous. I hope HKJ can test the VTC6A soon so we can have it in the comparator
It’s better to calm down. Nobody it trying to get you. We are just trying to learn. We flashlight guys don’t usually learn of a new battery until it’s available for retail sales so we can be a bit behind the times.
Do you have any idea of the difference between the 50G and 50E? Maybe they are the same battery just sold to different markets? I really can’t see any difference. They should both have the same capacity and current output.
That’s what a technician from QB told me: The 50G and the 50E, differs from each other by their respective chemistries which are different as well as their lifetime (depending on the discharge levels in amperes , depending on the use their life cycles will be different). Otherwise, yes for the specifications in general they are the same for both: Nominal 5000mAh and 10A continuous discharge. The 50E is officially intended for use in electric vehicle batterypacks (in short, they are certainly optimized for this use).
Wow, you’ve been on a 21700 buying spree! :partying_face:
There’s something about this statement that seems off “just like the VTC6 is better than the 30Q”. I remember some folks talking about how the vtc6 degrades faster or something. So I would put the 30Q as being the better cell. At least by a small margin. I can’t find that conversation. Do any of you guys remember this?
Okay, since I think most electric vehicles only charge their cells up to around four volts (for longer life and faster recharges) maybe they optimized the chemistry just for that application = Longer life and more charge/recharge cycles at 4v or less.
IDK, I’m just guessing here. Then the 50E is the consumer or general purpose version.
Yep there were some sales on 18650batterystore.com and there’s also free shipping when I buy over $100 so I thought might as well. Also I think VTC6 is better than the 30Q based on HKJ’s comparator. VTC6 also has more capacity.
Nobody else has any theory or assumptions, I accept even the craziest ideas? lol … I’ll give the answer in a few hours, by then, good luck. A clue: Myself, when I was looking for this answer a few months ago, I was building extravagant theories when the answer is not that complicated at first sight.
