1. Utilizes XHP 70.2 LED, with long lifespan of up to 5000 hours and a maximummaximum output of 4200 lumens.
2. Type-Cfast charging matches high capacity power source with battery indication function.
3. Sophisticated swith, all function controlled by one switch.
4. 6061 Aircraft grade aluminium alloy, so durable for long time usage.
5. Waterproof to IP68 standard. (2 meters submersible)
Package Included:
1 x Wuben T70 Flashlight
1 x 26650 Battery
1 x Lanyard
2 x Waterproof O-Ring
1 x Type-C Charging Cable
1 x Holster
click the pictures to get to the shop for more info
Instant Turbo: Press and hold to turn on the light, to activate Turbo in no time, click to turn off.
Instant strobe: Double click to turn on strobe, double-click to switch between Strobe and SOS, click to turn off.
Output selection: Click to turn on the light, if click will cycle through Low-mid-high-Turbo, double click will turn on Strobe mode, click to exist strobe mode, then it is on default output selection mode, triple click will get into flexible output selection mode, press and hold to adjust the brightness, release to select a certain brightness output between low and turbo, press and hold for 2 sec to turn it off, click will turn on the light on the output level while it was turned off. Whenever the light is constant on, triple click allows you to change the output selection mode.
Lockout and unlock: Triple click to lock it out, triple-click again to unlock.
I assume this is the cool white version since it’s from Banggood? Banggood doesn’t give a choice for neutral or cool white, but the description mentions the two versions. Also, you have another deal on your site that does have both the CW and NW version of this light for a little higher price. Just want to confirm which one Banggood is selling for this group buy.
That’s what I figured. I may have to get one of each (like I did with the A21). :money_mouth_face: I really like Wuben lights. They’ve become one of my favorites because of their high quality.
I did in fact just now order a NW version of this light from m4d-m4x-deals on Martin’s website from a different seller (not banggood). I have both versions of the A21, so I had to get both versions of this one too. They both (NW/CW) have their own different, distinct advantages. And I really like all of my Wuben lights. They are very well made, high quality lights.
As always, Thanks to Martin for feeding my expensive hobby and emptying my wallet!
