I had a starsky and hutch ’75 gran torino replica. can’t remember if it had the cleveland and i put in the windsor, or a windsor and i put in a cleveland. in any event, some jackass cut me off, and totalled it. i was a cop at the time, and i went to apply for the state police exam. they told me they didn’t want me when i pulled in the parking lot. i told them i probably wouldn’t take the job anyway because i was on the swat team and having too much fun.
One should swap the driver spring right after getting the Mini, its awful!, it causes lumen/lux flutctuatuins up to 20%. Otherwise, it if has a rear switch: the best nearly edc/all arround thrower light so far
Hi guys, after about 45 days my gt mini arrived today.
What mods are needed to have it draw the full 5.5A claimed? I was under the impression none…
First I tried a ~3 month old 35E that I took out of another light that was reading 4.11v and measured the current at the tail on turbo and I only got 3.32A so I charged up an also very good condition 30Q and measured again fresh off the charger (@4.20v) and still only get 3.35A.
Double click to turbo right?
Do I need to bypass the springs and maybe swap to 18AWG LED wires?
I don’t use a clamp meter, I have a .1omh shunt i use to make the connection then (with a dedicated-to-this-task DMM) measure the voltage across the shunt and run it threw ohms law. Same method I’ve used for years, it’s EXTREMELY accurate.
As a quick verification I just measured my eagle eye X6, it’s readng 5.25A which is exactly in line with what it should be doing (I keep record of all my builds and referenced it to check).
I’m very confident that my particular GT mini is truly only pulling 3.3A. Bummer.
How big is a visual brightness difference do you have from top-of-ramp to turbo? Mines very little.
Try a lux test. See how many candela it’s putting out. If it’s well below spec, then there might be something adding resistance to your light. I would check both ends of your battery tube to make sure you have nice clean bare contacts. Remove any oil or dirt. If no change, I guess you would need to bypass the driver spring. ¯\/¯
The jump from top of the ramp to turbo looks quite small. It’s 500 lumen, though.
