[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
Interested in NW or WW tint.
Interested.
Interested if it has a magnet in the tail.
so…its headlamp,not flashlight…angle type
INTERESTED! have kind of been waiting for the Acebeam H30 to come out but this one I might prefer.
Angle type is nothing, pattern of use is everything.
Interested
Interested!
Interested
With the compact small size, I wonder how it handles heat, considering it has 4 LEDs and uses a 21700, it seems to be designed to put out a respectable amount of lumens (maybe comparable to headlamps that use a single XHP50.2 or XHP70.2?)
I think BLF- standard 10-15s for thermal step down at turbo)
Interested
Very interested.
More chance of getting this anytime soon than an FW3A I think.
x3 AMCs seems about right for a useful torch. With good firmware, maybe not Narsil, no disrespect, too much going on with that which I don’t use, I’d prefer Anduril.
The right-angle form factor looks good to me. Not as a head torch, just a very practical arrangement, and small.
Could do with a better clip that fits top shirt pocket or belt. Not that skimpy little thing that would barely clip into a jeans pocket, it needs a lot more gape and to extend to the top of the head.
Some way of attaching a lanyard/wrist strap would be good. Even just a little hole in the tailcap. Olight manage to do this.
The subsidiary LEDs look like fun, just because they can be done, though I’d rather it was just 2 banks of AMCs + FET for efficiency. Better use of the limited MCU pins I think.
A bit like the craze for gimmicky tail light LEDs that I have resisted.
Not so keen on the 21-70 cell. Better just 18650, smaller, slimmer. I think 21-70 will turn out to be a gimmick with little traction. Still, an 18650 should fit provided springs can cope and a sleeve is provided.
Probably. Too much heat in a small space, so it won’t be able to sustain high output for long unless it’s water-cooled.
If it’s easy to reflash the driver in an assembled host, like if it has Lexel’s flashing connector in a convenient place, I’ll probably use it for testing new thermal algorithms. It seems overpowered enough to count as “hard mode” for the thermal regulation game.
Interested
interested
Agree with comment about the clip. A light like this it needs a good strong wide clip for use on jacket pocket, backpack strap etc or it’s usefulness will be limited.
Interested
This picket-clip looks like the generic one coming with every mateminco/astrolux/BLF 18650 tube flashlights.
They should go with a more dedicated-to-this-model pocket-clip or with this generic pocket-clip but with a little rework.
I’m fed up with this pocket-clip-catching-in-its-wrong-spot the pocket because the bent part is too short.
When you pull the flashlight down in your pocket, the edge of the pocket is going right here :
Instead of here, if it has a longer bent part (in red) :
Please, please FireFlies, make it right.
Or, even better, use an Olight-style clip which doesn’t have that problem:
