Maybe a HID?
It must be LEP or HID if itâs supposed to have a reasonable size (âflashlightâ).
I think itâs LEP. Short-arc HID is too complex for production.
To be more precise, I think they are using multiple blue laser diodes. Otherwise you donât get so many lumens.
Never know whats Lurking around the corner, always a Surprise or two. Maybe one day some peeon will do that too.
Next Question will be , â What exactly is the Definition of a Flashlight â.
Iâm not comfortable calling a Laser a flashlight, but thatâs a peeonâs opinion.
There is someone standing at the right side of a tripod, that gives an idea of the size of the box emitting the light. There is light âescapingâ the back of the box that is larger than the guyâs head, and because of the â3 petals cloverâ shape of the light at the back, I would speculate that it has at least 3 emittersâŚor 3 groups with several emitters.
It also looks like this âboxâ has some sort of syniosbeam form factor = much larger in the diameter than in the depth.
I tend to think the same.
You missed one, the GRB-080319B.
Oh, you said world⌠I thought you meant universe.
âThe afterglow of the burst set a new record for the most intrinsically bright object ever observed by humans in the universe,
2.5 million times brighter than the brightest supernova to date, SN 2005ap.â
Oh haha, I thought you were part of their team
Yeah, itâs definitely more than one, there isnât a single blue laser diode powerful enough for that many lumens.
Yeah me neither, but LEP isnât actually emitting laser light like a regular laser does.
Itâs just replacing the blue LED underneath the phosphor with a more narrow-band blue light diode, which in this case is a laser.
The list has been updated, now a laser flashlight has been added Maxtoch L2K
As well as a few others.
Still waiting on more info about the âLight of Xiuhtecuhtliâ (which claims >50Mcd) before I add it to the list.
Would like to know at least one more significant digit, it could be 50, it could be 51, or whatever.
Also itâs still not certain if they are using laser phosphor or some type of lamp.
Looking forward to adding more laser flashlights to the list in the near future.
The list has been updated for lights above 2Mcd.
Below 1Mcd I still have to add a lot of lights, since many LEPs and BLF-GT-like superthrowers.
Iâm planning a build based in a 5 gallon bucket with a 30cm fresnel, hope I can make the list.
As long as the battery is inside and the bucket has a handle, it should
âSâ ANSMAXABEAM RĂHRLE
Regards Xandre
SWEET. :smiling_imp:
My Viroblast (20cm fresnel thrower) is 6.2Mcd in the graph of the OP, but in reality it is 4.2Mcd.
@Xandre, the ansmaxabeam seems awesome, Iâm looking forward to the pictures on TLF
Yo,I am waiting for the pictures ,too (sma)
Your Viroblast makes me hot,
to try a fresnel .
Regards Xandre
Adding it right now! Very cool
Thanks for the correction
Please change it to LED CFT 90 plus collar Fresnel
and please write it in small or big letters
cause the name is not from Maxabeam
it is a mix from our names
you see I am small minded
The LEP picture was just a test (another project)
Thanks and best regards
Xandre
Haha thanks for the corrections, will do
It is nice to see an LED-based light in the top 5!
Thanks for the kind words-
As we started the LUXrace it was max 100 KLUX with LED
Best regards Xandre
1350m throw is only 455,625 candela, which is significantly lower than the 2,000,000 candela minimum to be on the updated list, sorry!
Maybe we should start a list for most powerful by lumens. Though itâs harder to verify claims and ensure lumens are calibrated correctly.
Thereâs this thread on the hottest hot rod and a few threads about specific cells but Iâm not sure if thereâs anything for brightest flashlights in general.
