The There Are No Stupid Questions Thread
1137 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 7 hours 34 min ago
Okay, so I might as well add the bleeder resistor to my light. Do you have a picture of where it mounts?
djozz
djozz's picture
Last seen: 43 min 55 sec ago
It looks like I scratched away some solder mask to make a solder pad.
JasonWW
JasonWW's picture
Gothcha, thanks.
djozz
djozz's picture
JasonWW wrote:
Gothcha, thanks.
do you ever sleep?
JasonWW
JasonWW's picture
djozz wrote:
JasonWW wrote:
Gothcha, thanks.
do you ever sleep?
I’m a night person. Assuming your a day person, then you and I are probably awake and asleep at very simular times. So it just SEEMS like I’m awake all the time. Wink
Geuzzz
Geuzzz's picture
Last seen: 1 hour 49 min ago
I scored a V11R that I want to mod.
Want to put a 5D xm-l2 in it, but I can’t find a good source for the led. Intl outdoor has a minimal orderqt of 5 making it 35 dollar ex shipping.
Anyone know a good source?
BlueSwordM
BlueSwordM's picture
Last seen: 6 days 8 hours ago
So, guys, I’ve tried to remove the driver side retaining ring on my Astrolux C8. I’ve tried doing it clockwise, counterclock wise, but nothing works.
My hemostats manage to unscrew retaining rings on every light I have, except this one.
Some help would be very thankful.
@Geuzz, there is this:
https://www.digikey.com/product-detail/en/cree-inc/XMLBWT-00-0000-000BT6...
A bin lower than the MTN Electronics bin, but much cheaper including shipping.
Geuzzz
Geuzzz's picture
Thanks for the help, but shipping to the Netherlands kills it.
I ordered an even lower bin at fasttech, but I am still looking.
Btw. Astrolux c8 is one of the few c8s I never had. Can’t help you with that one.
BlueSwordM
Yeah. Digikey and Mouser are the only source for some reason where I found XML2 5Ds, but shipping kills it as you said.
MascaratumB
MascaratumB's picture
Last seen: 12 min 51 sec ago
I’m just thinking, but being a small thing, wouldn’t it be possible to ask someone from US to buy it for you them send in a normal envelope as a letter?
Unfortunately, buying from MTN has a very expensive shipping, so that could be some alternative, if there would be no damage for the LED
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior / OW Mini // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 / i5 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R / E61 // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review’s Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
Lightbringer
Lightbringer's picture
Last seen: 15 min 44 sec ago
Beat me to it. Was gonna suggest
https://www.fasttech.com/search?xm-l2%205d
but yeah, they’re a little bit lower in output.
manithree
Last seen: 19 hours 40 min ago
So, I’m waiting for a couple of C-AA sleeves to put some AA eneloops in this light.
I’m wondering if it’s possible to take a busted incan base, solder in a Yuji 5mm from mtn and just drop it in? Is DD from 2S AA gonna kill it?
BlueSwordM
Would not kill it, but overdrive by quite a bit if you were to use alkaline AAs. DON’T PUT IN LITHIUM AAs though. Their open circuit voltage is 1,8V, so that would be 3,6V and probably kill the LED instantly since it draws very low currents.
Just put in 2xNiMH AAs and you will be fine.
manithree
Cool, thanks. Eneloops ONLY is the plan. I’m hoping I can use an old incan base, then if it doesn’t last long, I can easily replace it.
I thought I had some C-sleeves, but it turns out they’re D sleeves. So I’m waiting on the sleeves and the LEDs for now.
pennzy
pennzy's picture
Last seen: 15 min 36 sec ago
Why does my spell check keep flagging “lumen”?
Sillen
Sillen's picture
Last seen: 10 min 16 sec ago
What does “BBL” mean on tint chart?
BlueSwordM
Black Body Locus.
It’s basically the color path of a perfect heater, or incandescent light source, known as a black body, that it would take at a certain color literal temperature, like 3000k, emitting light in every possible wavelength at a perfect sunlike color reproduction.
Going above the BBL means going to higher wavelengths, meaning going towards blue, or worse, green wavelengths.
Going below the BBL means going to lower wavelengths, meaning going to Nichia 219B’s rosiness level.
Grappler
Last seen: 6 months 3 weeks ago
Is it bad that my charger shows 4.22 volts when finished charging Li-ion batteries? If so, how much of a problem is it? Should I return the charger under warranty?
Thanks!
BlueSwordM
As long as it doesn’t exceed 4.25V, you will be fine.
Just discharge the cell inside of a light for a few seconds, and it will come back down to 4.2V in a jim.
JasonWW
JasonWW's picture
Thanks!
I would double check the voltage with a DMM.
CNCman
CNCman's picture
Last seen: 6 min 30 sec ago
I you have a driver, do you need the R1206 for correct operation in 12v configuration. Or do I remove and jump it with solder.
This is for a high amp mod. Question
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
LichtAn
Last seen: 3 weeks 1 day ago
Why is it so much harder to desolder components from factory than it is, when you did them yourself. Tried to desolder a driver spring yesterday and cranked my 60W iron up to 380°C with a big chisel tip, still nothing. Using desoldering braid it even gets worse. Had to get it off with a regulated blowtorch.
JasonWW
JasonWW's picture
The factories may be using lead-free solder (for health and safety regulations) which has a higher melting point then the leaded solder that most hobbyists use.
LichtAn
I suspected this. But how much higher should I go with the temperature?
Cereal_killer
Cereal_killer's picture
Last seen: 9 months 3 weeks ago
Your heat setting is probably not totally incorrect, try this-
First FLUX IT, flux it real good.
Then add a tiny amount of your solder.
Now try again.
Cereal_killer
For 12v operation you leave the jumpers open and short the R1206 pads (a 0ohm 1206 size resistor or a solder blob is fine), for 6v operation you leave the resistor pads open and sort the 2 jumper pads.
LichtAn
Cereal_killer wrote:
Your heat setting is probably not totally incorrect, try this- First FLUX IT, flux it real good. Then add a tiny amount of your solder. Now try again.
Also tried that. Flux burns off gradually and I get a nice shiny blob of new solder on top of the old solder. Maybe I need a more aggressive flux, I just have tacky no clean flux.
Cereal_killer
You need some good, liquid flux like Kester
LichtAn
I got Chipquik and Stannol. Should do?
JasonWW
JasonWW's picture
What iron do you have?
