I believe what people were reporting is the behavior Im documenting in this thread, when the battery goes below 3.6v
Yes, the battery detection of the light I am testing, a Novatac SPA Defense 120T, is set to 16340.
If I insert a CR123, below 3v, the light steps down through all higher modes, and goes into visible lowest mode strobing and will not produce any of the other brighter modes. This is also true with the 16340 below 3v.
The point of this thread is that below 3.6v there is also a visible flicker signal, that can be used as a reminder to charge the battery, before losing access to all the other modes. The flicker Im posting about, just below 3.6v is separate from the Low Voltage Warnings, that start at 3.0v
a note about the battery detect reset on Novatacs
because the instructions require holding the button during the dim light that only lasts 1 second when the tailcap is tightened, I find it easier to simply hold the button when tightening the tailcap. But, be sure to release the button after 5 seconds, this will only reset battery detection. IF the button is held for 10 seconds, it causes a Factory Reset, and the 250 clicks will be required to reenable Programming.
iow, my Novatac 120T is cracked to act like a 120P.
FWIW, battery resets are not automatic, and the Novatac STAYS in 16340 detection mode, even after multiple battery swaps, even if the battery is removed to check for voltage, and it falls below 3v.
On a modern HDS, you cannot open the light and reinsert a LiIon that tests below 3v, or it will reset the battery detection automatically to CR123 Primary, thereby causing OVERDISCHARGE of the LiIon. This is why I prefer to use Protected LiIon, and I do NOT rely on the Low Voltage Protection built into an HDS, or Novatac. The Novatac remembers its 16340 setting, and an HDS will “forget it”, when inserting a LiIon below 3v.
FWIW, My Novatac will also flicker both visibly and photographable, when set to its 5.4 lumen mode. It does this even on a fully charged battery. The bottom line is Novatacs have lots of different Flicker Features
