Manker T02
36 posts / 0 new
blackbalsam
I Like it. I’ll buy one.
Cereal_killer
Cereal_killer's picture
Last seen: 9 months 17 hours ago
I really like the tail cap design! Now if only the UI wasn’t rediculous I’d have ordered already!
Thetasigma
Anyone out there that has one of these? I’ve been on a side by side kick lately and a 2xAA SxS is of interest.
Main things I’m curious of are the build quality, particularly the battery cap mechanism, if the NW version is tolerable and what CCT it is, and how the UI is in practice
JASII
Last seen: 4 months 2 days ago
Bought one on Black Friday, received it 12/27. Nice light with a quality build. Here’s my question….how do you unlock the light. Instructions tell you how to lock it, but not unlock it! And I tried repeating the lock procedure and it didn’t work. Took the batteries out, didn’t work either.
Edit: Turns out it was the lock procedure to unlock it. I tried it several times and it didn’t work. Tried many other combinations to no avail. Kept at it with the lock procedure and it finally worked.
TexasToasted
TexasToasted's picture
Last seen: 3 hours 15 min ago
Build quality is good, but the tailcap threading is very small and easy to cross thread. It takes me a few tries to get the tail screw aligned correctly with the body threads.
My light is flakey. Sometimes it works fine. Sometimes it triggers a low voltage warning when the cells are full. Sometimes it gets confused and stops responding to button presses. Usually, I have to remove the tailcap and reinstall it, to reset the driver.
I did have the same problem with lockout. I think I fixed it by switching from AA batteries to 14500 batteries. Mine works a bit better on 14500 cells. By better, I mean the driver doesn’t get confused as often as it does on AA cells.
I also have a Maker U21 and it has even worse issues that the T02. I’m not buying any more Manker products.
