[Review] Rofis MR50 (XHP-50.2, 21700, e-switch) ~ 22/09 Outdoor Beamshots Added
15 posts / 0 new
bilakos10
bilakos10's picture
Last seen: 11 hours 56 min ago
The flashlight was sent to me by RofisLight for review.
Here's the product's link for more info: Rofis MR50
The flashlight arrived in a nice cardboard box.
Rofis tends to always include lots of accessories with their flashlights.
In the case of the MR50 you get the following: a carrying pouch, an adjustable wrist strap, a microUSB charging cable, a USB OTG adapter and a user manual.
The sheath is made out of nylon and it's well constructed.
It implements double belt loops and a hoop.
The MR50 follows the design line of the rest MR series flashlights by Rofis.
It's e-switch operated and the head/body assembly is a single piece, while there is knurling along the body and tail.
Opposite to the switch you get the charging port.
The protective rubber flap is quite thick and provides a snug fit.
I have always been a fan of Rofis' e-switch buttons - especially the ones used in the MR series.
The concave shape of the switch makes it very comfortable and easy to locate.
The switch is protected by a metal ring and it sits almost flush to the lip of that ring.
The threads are square cut and came prelubricated.
The tail implements a dual gold plated spring design which is mandatory due to the flashlight's power requirements.
Here's a look at the light's driver.
As I have noted, the head/body assembly is one continuous piece.
The Neutral White XHP-50.2 emitter sits inside an orange peel reflector which creates a wide hotspot.
The bezel is made out of polished aluminum and has a dark grey coating.
The light comes with a protected 21700 cell included.
The cell is Rofis branded and has 5000mAh of rated capacity.
It's flat top.
Here's the current that I recorded while charging the cell from my Xiaomi powerbank - the cell was half full.
With a fully discharged cell I recorded up to 1.9A of current so it's safe to say that the max charging current is set to around 2A.
Thanks to the included OTG adapter, the MR50 can also be used as a powerbank.
Using my RDTech UM34C meter and LD25 electronic load, I verified that the MR50 can output 2A of current.
User Interface
The MR50's interface is intuitive and quite easy to remember.
Here's the supported actions:
Turn on/off: Singe press.
Mode cycle: Long press while on ( Low > Mid > High ).
Turbo: Double press from any mode (on or off).
Location mode: While off, long press for 3 secs. The indicator LED will start blinking in red in 1 second intervals.
Lock / Unlock: While off, long press for more than 5 seconds. The light will flash a couple of times to indicate that the lock is engaged. Repeat for unlock.
Strobe: Triple press from anywhere.
SOS: Long press for 1 second while in Strobe mode.
Once the battery is inserted, the integrated indicator LED in the e-switch will light to indicate the charge level (Green: > 40%, Red: < 40%)
Also, once the battery's level gets low while in use, the indicator will start shining in red.
Performance
I took my measurements using the included Rofis branded 21700 cell.
Here's turbo compared to my other lights.
My tests showed that the MR50 is indeed pushing more than 2300 OTF lumens.
I also measured the pasatic drain, which turned out to be 165 – 215 μA
Outdoor beamshots
As with most products by Rofis, the MR50 is a well thought out flashlight.
Its construction quality is great while it packs a lot of power.
After all, it's great seeing another manufacturer going the 21700 route!
Edited by: bilakos10 on 09/22/2018 - 09:17
weklund
weklund's picture
Last seen: 2 weeks 3 hours ago
Excellent review. What a great light.
... Happy Landings ...
bmengineer
bmengineer's picture
Last seen: 2 weeks 3 days ago
^ that’s the MR70, not the MR50.
Find all my reviews of flashlights and more gear at www.bmengineer.com
weklund
weklund's picture
Oops …. you are right. Sorry about that. Post revised.
My apologies … Smile
bilakos10
bilakos10's picture
No need to apologize!
All of the MR series flashlights follow the same design lines.
Both the MR50 and MR70 are one of the best choices in their respective category.
desmondkun
desmondkun's picture
Last seen: 13 hours 58 min ago
Why Convoy L2 has so low lux in the chart?
Take care of your flashlight and your flashlight will take care of you.
bilakos10
bilakos10's picture
I chose to go with a 3000K XP-L HI so it’s possible that I have gotten a lower binned emitter.
Also, I have noticed that the meter I used in the L2 review measures quite a bit lower in super warm lights.
After my review, I modded the L2 with a regular 17mm fet driver and I am getting around 1300 OTF lumens Smile
Tom6
Last seen: 6 months 1 week ago
Are this NW version?
clemence
clemence's picture
Last seen: 1 month 3 hours ago
Thanks for the review. It looks cool and a good host for many project with the higher capacity 21700 and boost driver.
Is it only me or just me?
I’m always excited to see new flashlight reviews. And the most anticipated part are the beam shots and runtime… Sad
- Clemence
bilakos10
bilakos10's picture
- Clemence
Outdoor beamshots incoming this evening!
VictorB
VictorB's picture
Last seen: 7 months 2 weeks ago
Hello! Great review!
This flashlight seems very attractive to me. I’m thinking of buying one or two. In the characteristics shows that in turbo makes two stepdown. How long does it take to do them?
bilakos10
bilakos10's picture
As promised @Clemence , here's a few outdoor beamshots!
clemence
clemence's picture
bilakos10 wrote:
As promised @Clemence , here’s a few outdoor beamshots!
Big thanks Bilakos10! LOL
Nice big hotspot and bright spill, very useful for navigating in the woods
- Clemence
Tom6
Are there NW version? Eee Bill?
bilakos10
bilakos10's picture
The MR50 I was sent used a CW emitter. I believe there hasn’t been a NW version of this light so far!
