My intentions is not really to try and squeeze out more juice, but to make sure they didn’t use that crap white rubbery thermal paste, and that the LED has got enough heatsinking behind it so that it can handle the heat. I modified my BTU Shocker into a SuperShocker over the weekend, and I was surprised at the crap thermal paste, very thin LED shelf and big unutilized gap between the LED shelf and the driver. Filling that with copper or even aluminium will help the LEDs a lot, and I was wondering how the BLF GT70 would compare.
There are 150 different levels. The run times will vary depending on the level and whether your using 4 or 8 batteries and what type of batteries. That’s about all I can tell you. I’m not sure about specific run times.
The white thermal paste is really not that bad in my testing. When it comes to OTF lumens, it made virtually no difference. Heck with enough clamping pressure no thermal paste at all was only a few lumens behind.
Sorry for the misunderstanding… I measured both olight st96 and mt18vn with the TA tube… TA tube show 10500 and 10720 lumen… then I use light meter app to get the all the lux reading. That’s the only way I can get good reading on the blf gt lights…
Yes sir… it is not the right way to measure lumen… i know two lights are measured by TA tube and use them as a reference… the lumen number are pretty good as you can see by my testing… those are @5 seconds lumen…
Ah, I see. The silicone thermal adheisive is still not horrible IF it is properly clamped down before letting it dry so it is as thin as possible. I have done this in a few hot rods and it works great.
Now in most lights it is used in, they do not clamp the mcpcb down so it is way to thick and yes, then it is positively horrible.
Lumintop BLF GT Flashlight DIY Short Body That’s the page at BG for the shorty tube but go to Martins site and join and get the code under Lumintop and that will take off $5,
$20 is a bit steep to me and I can’t just give out the code or Martin would scalp me or worse, but that price does give me a good clue as to what an full extension tube might cost.
Kind of funny at Lumintop, the secondary Giggle code for the conversion kit didn’t seem to work so I got hold of Victor and he fixed it for me, he brought the cost down to $83 for the kit and two extra carriers,
I have no idea what the discount would be but no matter I’ve gotten a good deal from Lumintop since day one, but then after I paid up it asks if you want to go to the home page and so I did and I noticed right on their home page another code for the GT that brings the price down to $220, ha ha… wow
I guess the GB might be sort of over with if their advertising a code of their own as well, I can’t help wondering why bother with these codes, just sell the light for $220 and skip the codes, nothing is secret anymore, there’s codes everywhere.
But, out of all the codes I’ve seen TA’s code is the very best so Giggle that…!
So you measured 2 lights with the tube.
Then you measured both with ceiling-bounce (cb) and set the factor in cb to a value, so that cb shows the same amount of lumens as the tube?
This way you could get reliable results with cb afterwards for all other lights…
(not taking into account, that different reflector characteristics will for sure also have a large effect on the results)
Yeah, that was what I was referring to. I’ve modded a few lights (not that many compared to others, but Skyray V2, 9xT6, Solarforces, BTU, etc) and each time it is easy to desolder and solder the PCB leads when the copper PCB is on those white thermal paste. Replace that with Arctic Silver 5, and you actually struggle to solder leads to the PCB, the heat is just pulled away too fast and I have a 80W 380’C regulated soldering iron. With the fat tip you have to hold it quite some time to warm up the PCB, PCB shelf and wires.
That led me to thinking that while better thermal paste won’t give you more lumens OTF on a cold start, it might give you a higher sustained lumens OTF because the LED wouldn’t start thermal throttling, and it might even prolong LED life? If I can open my GT70, I’ll do a comparative test when I get it
