The Sofirn SP31 V2.0 is the latest version of the SP31 and the newest 18650 light from Sofirn. Although this is my first Sofirn light, they are known as a quality, budget friendly flashlight company. I’ve had a chance to use this light and put together a review and specs that might help you with when considering this as a purchase.
What’s in the box:
1 Sofrin SP31 V2.0 Led flashlight
1 Sofrin 18650 battery 3000 mAH
1 USB Charger
1 Lanyard
2 Spare o-rings
1 User manual
First Impressions:
First of all Sofirn has upgraded their packing from a plain brown box they have been known to send out. Everything about the light looks and feels like a quality build. The stainless steel clip is sturdy and already installed. The knurling gives the light a good feel and nice grip. The user interface is easy and simple to use. I really like the modes programmed into this light. The moonlight mode or Eco as they call it is 5 lumens and good for close up work and the 1200 lumen mode is super bright and really lights up an area. My only complaint is because of the design the light will not tail stand. I have been informed this will be redesigned in the near future.
Features and Specs:
- 1200 lumens in turbo mode
- Cree XPL-HI LED
- 200 meters throw
- 5+2 light modes
- Variable strobe for more disorientation
- Aircraft-grade aluminum alloy
- Premium type Ⅲ hard-anodized, anti-abrasive finish
- Impact resistant 1 meter
- IPX8 water resistant, it can be used in heavy rain
- Battery Power Indicator
- Low Voltage Warning and Protection
- Advanced Temperature Regulation (ATR)
- Reverse Polarity Protection
- Mode Memory: record the last mode, when used around 2 seconds
2.54 oz (72g)
*113.5mm length, 23.4mm head - Smooth reflector
- 1pcs 18650 Battery or 2pcs CR123A Lithium batteries
- 5350K-5700K, Neutral White
- Working Voltage: 2.8-8.4V
- Copper base
- Toughened glass lens with AR coating
For size comparison this is the Sofirn SP 31 in between the Convoy S2 and the Thorfire VG10s.
Operation:
The Sofirn SP31 operates with 2 switches, the tail forward clicky switch turns on and off and also provides a momentary on. The side switch has 5+2 modes. 5 brightness levels and 2 hidden modes, strobe and SOS.
5+2 Modes: Eco (5LM) → Low (50LM) → Medium (160LM) → High (500 LM); → Turbo (1200 LM); hold 1.2 seconds for Strobe & SOS
Runtime: Eco (5LM) 291 hrs, Low: (50L) 26 hr 49 min, Medium: (160L) 9 hr 45 min,
High: (500L) 3 hr 41 min, Turbo: (1200 L) 2 hr 37 min.
The SP31 features Advanced Temperature Regulation (ATR). The light will automatically adjust the brightness levels when the driver temperature goes above 140F (60C). Also on turbo the light features automatic step down after running for 3 minutes.
Battery Capacity Indicator (LED on the side switch)
The indicator is on for 5 seconds every time when light turns on. It shows green or red to indicate the battery power.
Steady Green: good power
Steady Red: low power
Flashing Red: running out of power. Time for a new battery.
Tail and Head
Smooth Reflector
Overall Impressions:
I really like this light. I wasn’t sure how much I would like the two switch operation but I can really see how easy it is to operate. I love the different light levels from turbo at1200 lumens down to moonlight or eco mode as they call it at 5 lumens. I’m finding that I use the moonlight mode as much I do the turbo mode. The turbo is super bright and really throws the beam. Strobe is easy to access and it is separate from the other modes, so I don’t always have to cycle through it. Great light and a good value.
Full Disclosure: I was provided a sample for review. Please know I have given my honest thoughts on this product.
