Emisar D1S Oslon Black flat mod 340k+cd
103 posts / 0 new
mikelights
mikelights's picture
Last seen: 11 hours 5 min ago
I just finished up modding my D1S with a Oslon black flat , all i did was reflow the LED on to the xp board that came in the light. I put the MCPCB back into the light, shaved down the centering ring to fit the new LED and viola it worked!, it now produces 345kcd and ~707 lumens comapred to the 140kcd and 1200 lumens. LAZER BEAM TIME
Some Pictures, a video will be up soon @ https://www.youtube.com/channel/UCcWcPSMe1ohtcYf3BHsaldA?
Compared to a D1S XPL-HI
Current collection
Olight -S1R -I3E EOS -S mini brass -S2A -X7R -S mini copper Sofirn -SP33 Nitecore -TM06S Thrunite  -TN42 -TN40 ThorFire -S70S -TG06S -TK05 Manker -Mk34 Noctigon Emisar -Meteor M43 -Emisar D4 -Emisar D1 -Emisar D1S -Emisar D18 -Emisar D4S Rofis -TR31 Lumintop -BLF GT -GT Mini -IYP365 -Tool AA 2.0 -FW3C Acebeam -X80GTvn -W30 Imalent -R90C -MS18 FireFlies -E07 Brass Reylight -Pineapple
Product Reviews
Chargers:
Opus BT-C3100MiBoxer C4-12MiBoxer C8Folomov A1
Flashlights:
BLF GTTN42TG06SEmisar D4GT MiniS70STM36EDC-C4BLF Q8W30
Custom Builds
XPL-HI C8, Aspheric XHP-70OSLON D1S
Edited by: mikelights on 09/17/2018 - 23:32
EasyB
Last seen: 7 hours 47 min ago
Nice. Is that the D1S with XPL HI in the comparison shots?
mikelights
Yes it is! Just updated the thread to say the comparison light
Current collection
Product Reviews
Chargers:
Flashlights:
Custom Builds
Enderman
Enderman's picture
Last seen: 3 min 43 sec ago
That’s a nice tight beam right there Smile
T18
Last seen: 9 months 2 weeks ago
I always thought those were very expensive but I guess not, quite a surprise at under $5..
That is just awesome, you should be able to light up some satellites going by with that D1S..
-X3-
-X3-'s picture
Last seen: 20 min 17 sec ago
I thought the Oslon black flat were weird to feed, like with a P-Fet or something Davie
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
mrheosuper
Last seen: 7 hours 19 min ago
wait, isn’t Stock MCPCB is DTP
did you also change the driver?
Forgot my pen
LichtAn
Last seen: 7 months 2 weeks ago
“shaved down the centering ring to fit the new LED
What do you mean by shave down? Because the LED is sitting lower than the XP-L HI?
Andrew_Debbie
Last seen: 5 days 20 hours ago
The data sheet Vf is 2.75(min) 3.05V(typ) 3.75V(max) at 1amp. Rated forward current is 50-1500mA. Maximum rated pulse current is 2.5A.
LichtAn
He’s talking about the thermal pad not being electrically insulated.
Andrew_Debbie
Ahh. I’m still learning.
From the data sheet:
-X3-
-X3-'s picture
So, any explanation ?
Is it as simple as a reflow on the stock Noctigon and voilà ?
zeroflow
Last seen: 3 months 1 hour ago
My best guess:
A lot of non-conductive thermal paste was used and the DTP-MCPCB is just isolated from the driver by sheer luck.
Otherwise you would need an isolated MCPCB as those from led4power which use a special aluminium oxide layer to have near DTP-performance on isolated MCPCBs
-X3-
-X3-'s picture
zeroflow wrote:
My best guess:
Yeah I was thinking the same… Heat path is not ideal in that case Sad
LichtAn
X3 wrote:
zeroflow wrote:
My best guess:
This might be 100% wrong. But I vaguely remember someone saying that the Emisar boards have a P-FET?
ImA4Wheelr
Very cool build mikelights.  Congrats
This might be the same emitter at Arrow for lower cost and free overnight shipping:
https://www.arrow.com/en/products/luwhwqp-8m7n-ebvf46fcbb46-1/osram-opto-semiconductors
EDIT:  I just read here that there are what sounds like higher binned ones at mouser and digikey, but I can't seem to find them.  I can't seem to match up the manufacture's part number to the datasheet.  The listed specs appear to indicated the highest light output, but also highest Vf.  They are only showing max's though.  So not sure about that.
EDIT2: Please disregard the struck out text.  Member Nicolicous alerted in Post 31 below that this is a 5-pin package that may not be compatible with XP based.
CRX
CRX's picture
Last seen: 13 min 13 sec ago
Cool.
- LEDs & Other Stuff -  - UI CheatSheets -  - CRX Mods & Builds -  - Stuff for Sale -CRX Hand Made FlashlightsThe only place that fear can exist is in our thoughts of the future.
It is a product of our imagination causing us to fear things that do not presently and may never exist. Fear is a choice.
giorgoskok
giorgoskok's picture
Last seen: 2 days 20 hours ago
The Emisar lights don’t have a p-fet driver .
The explanation : the driver’s ground , isn’t connected (electrically) to the head , but only the tube is , that carries the Battery (-) .
That allows the head to be connected with Led (-) without causing issues on the driver .
-X3-
-X3-'s picture
Annnnnd thank you very much for that clear explanation, I couldn’t for the life of me figure how it was possible.
You couldn’t do that in, say, a C8…
Now I have to order some black flat Facepalm
EasyB
True about the head being isolated from battery negative. I didn’t think of that. But I wouldn’t necessarily rely on this method of isolation because if the anodization of the tube threads wears off it’s no longer isolated.
A method to isolate the MCPCB from the shelf that’s worked well for me when I was experimenting with making XD16 arrays is using narrow strips of kapton as spacers under the MCPCB. A couple small strips (~2mm x 15mm) near opposite edges of the MCPCB prevent any metal to metal contact. Put the strips on the MCPCB and use ceramic thermal paste as usual. The kapton thickness is only 50microns so it’s practically not adding any thickness to the thermal paste junction.
giorgoskok
This is a rare occasion , since most people change battery from the tailcap side . Someone could add some (veeery little) medium strength threadlocker to be sure they won’t change battery from this side , and so it won’t wear off .
mikelights
mrheosuper wrote:
wait, isn’t Stock MCPCB is DTP did you also change the driver?
Yes but since the head isnt electrically connected to the driver I didnt need to change anything except reflow the LED.
Current collection
Product Reviews
Chargers:
Flashlights:
Custom Builds
mikelights
I had to sand down the little centering ring for the led to get optimum focus and shave it out a bit to make the hole bigger so the black flat would fit, the black flat is a bit wider than the XP-L HI
Current collection
Product Reviews
Chargers:
Flashlights:
Custom Builds
mikelights
X3 wrote:
So, any explanation ? Is it as simple as a reflow on the stock Noctigon and voilà ?
simply put yes it is, I was expecting to have to isolate the MCPCB but I didn’t have to because of the isolation between the head and driver which made the build process a lot easier and quicker
Current collection
Product Reviews
Chargers:
Flashlights:
Custom Builds
mikelights
EDIT:  I just read here that there are what sounds like higher binned ones at mouser and digikey, but I can’t seem to find them.  I can’t seem to match up the manufacture’s part number to the datasheet.  The listed specs appear to indicated the highest light output, but also highest Vf.  They are only showing max’s though.  So not sure about that.
Thanks! and thanks for the info I will check out that site you linked
Current collection
Product Reviews
Chargers:
Flashlights:
Custom Builds
mikelights
precisely
Current collection
Product Reviews
Chargers:
Flashlights:
Custom Builds
mikelights
originally I was going to use thermal epoxy on the bottom of the driver to isolate it but I didn’t need to because of the driver isolation, but my solution is not to unscrew the body from the head just use the tail cap which keeps the threads from ever getting worn down.
Current collection
Product Reviews
Chargers:
Flashlights:
Custom Builds
giorgoskok
I made mine too some days ago , now I’m messing with the focus to get the optimal result Smile
mikelights
!{width:80%}https://i.imgur.com/OFSPux1.jpg!
Awesome! let me know the max cd you get out of yours I am curious how they compare
Current collection
Product Reviews
Chargers:
Flashlights:
Custom Builds
mikelights
Thanks haha, it turned out awesome
Current collection
Product Reviews
Chargers:
Flashlights:
Custom Builds
Nicolicous
Nicolicous's picture
Last seen: 1 min 27 sec ago
That link is for “Automotive 5-Pin SMD T/R”….I don’t think it can reflow to your xpl mcbpc.
Arrow do have 2 -pin but not in stock. I got their email reply of 10 pieces for $21…. Seems good deal
Think I’ll pull the trigger soon Smile
Nico -.-
