I can’t watch the videos due to a web filter at work, but I’m eager to get home and watch them!
It’s hard to interpret what he meant, not knowing the camera settings.
For a rough idea what to expect, put a layer or two of matte finish tape (eg- Scott Magic) on a ~10 lumen light.
This will not be a throwy light, nor high output. but it should be fine for finding your way around the house, checking your glovebox, helping use your keys, reading, and many other uses.
Ran over by a car, fell off the core support and slung across the shop, fell out of my pocket doing 60 on a motorcycle. Yeah my old light was beat to snot and well used. Reason why my my brand and even model of go to light hasn’t changed.
Yeah the motorcycle made my stomach turn. Was surprised it only slide over to the ditch without doing anybody any damage. Bigger surprise we even found it. You see me you might laugh but it’s the reason why I have everything tethered and clipped down.
Actually, there’s not much in it. The Yuji LED puts out about 6lm at 20mA and about 3V. That’s about 100lm/W, so efficiency is OK.
Output is low compared to a similarly-sized COB, but this is meant to be a last-resort light, so there’s a tradeoff: lower output for more runtime.
The 5mm LED also has the significant advantage of being completely encapsulated in all directions, which helps with robustness - another desirable characteristic of a last-resort light. The shape of the package even gives it a built-in lens.
That’s close to the worst case specified performance. Best case is 2.7V and 8 lm at 20mA, which would be 148 lm/W.
Considering this is a 95+ CRI emitter, anywhere in that range is pretty decent, and the high end is good enough to be hard for me to believe. When djozz tested an 80+ CRI Nichia 219C, his numbers at the closest datapoint to the rated current worked out to 139 lm/W.
Why not have three of them and get read of the useless reflector to triple the output?
That would not add much complexity and should not impede robustness either?
Sorry about the argument but i’m having a hard time wrapping my mind around a new 2018 light putting out only 8 lumen…
It is much more about runtime as it is about output, it is build as a last resort light, 8 lumen compared to no light at all is huge, also in 2018.
But what that 95CRI does in a last resort light is highly questionable of course
What does ANY kid do, when you give him a flashlight, no matter - as a gift, or to use for a short while? :smiling_imp:
Literally, every child turns it on and looks into the bulb/led, whatever the ligh source. When the kid has made sure there are no monsters under the bed and in the dark bathroom, he or she drops the flashlight on concrete floor, in water, disassembles it, changes polarity of the battery, whatever. Afterwards, if the flashlight has survived, he / she leaves it on…
Don’t you still see a use for a 8 lumen, crash, water and freeze safe flashlight in 2018? The only issue left in this is disassembling…
Barry mailed me some other test results, mail=below. He is concerned that we think the output is too little. But we decided on 25mA because of durability and of runtime, so the output is what it is when you use these Yuji leds. They may come with a cool white low CRI version at some point, that would have an output over 10 lumen.
Hmm, hot?
They run at 25mA, that is ~75mA on the battery, on average 1.2V so 0.09W, of which 0.06W is heat. After 20 minutes the light may feel slightly luke-warm, probably not at all.
Any chance we can bump it up to 35 mA? The beam is more diffused than an E01 which means it’s really going to be difficult to use this unless in complete darkness.
Especially with the warm white at 5.5 lumens, I’m concerned whether this light will have any everyday use at all.
That would be an interesting add, if it will be a later option!
So far, I’m happy with the results and I don’t think this kind of light would need much more. It is what it is, it will serve for the designated purposes! I wanna stick a battery into it, forget it is there, and then, when needed, use it for the longest time possible.
I (colective “I”, meaning most of us) will - probably - have other lights to use with more output.
Thanks again for all the tests and work so far! BTW, I guess this light can also be used as a “thrower”: you throw it to someone’s head and…good luck to that someone’s head :smiling_imp:
You will have to accept that this light does not put out a lot of light, the current was discussed before and for sake of led lifetime and runtime of the flashlight it was (as discussed in this thread) decided on 25mA, as compromise between output and runtime.
You will be amazed if you have no other light than 5 lumens available how useful it is. One application, for me with its 60 degrees flood led it will be and ideal reading light without disturbing others around me who are asleep.
I like the tests Sofirn has done, especially the rapid temperature change test (number 6) :THUMBS-UP: . An extreme version of this test would be if you did it the other way round (first cold, then hot): -35°C for at least 30 min, then immediately put the light in hot water that has just boiled a moment before (~ 90°C), I mean its a totally realistic scenario O:) , imagine you are working in the Arctic (or Antarctic) and forgot to bring a spoon, so you use your light to stir your freshly brewed coffee :D .
The lumen numbers (5,5 lm & 7,5 lm @ 25 mA) seem a bit below spec (the warm white quite a bit, the neutral white only slightly). If we were to increase the current to 30 mA we would get about 6,41 lm for the warm white and about 8,75 lm for the neutral white.
The question is if the slightly higher lumens are worth the trade-off in runtime.
At 25 mA and a power draw of 0,09 W from the battery (as per dijozz's calculation) we would get a calculated runtime of 10 h with a standard eneloop, a bit over 12 h from an alkaline and 20 h from an Energizer lithium.
At 30 mA and a power draw of 0,11 W we would get a calculated runtime of a bit over 8 h from an eneloop, 10 h from an alkaline and a bit over 16 h from an Energizer lithium.
Keep in mind these are only calculated runtimes, it would of course be great if Sofirn could do some runtime tests so that we have some proper data.
