Emisar D1S Oslon Black flat mod 340k+cd
That isolated head so you can use the Black Flat is already reason enough to buy a D1S. Great mod with awesome throw for such a small flashlight!
So true! Thanks and I’m glad you liked it
Nice find!!! This is great!!!..so the D1s and flat black are secretly the perfect match. I love how little spill the corona has now.
I’m still alil confused on how the head is electrically isolated. Is it simply the thick anodising emisar uses? Because I dont recall ever seeing a grommet or spacer in-between the head and body?
Definitely a match made in heaven, the thick anodization insulates the driver from the head because it’s simply push fit into the light so therefore the negative outer ring on the driver only makes contact with the body and it’s electrically isolated from the aluminum in the head, as we were saying before if you take apart the D1S from the top of the tube near the head the threads will wear off the anodizing from friction and will soon ground out to the head and ruin the connection once it wears off but you can take care of that by only unscrewing from the bottom of the tube.
Oh. Thank you Nicolicous. I scanned a datasheet, but didn't catch anything about that package. I'll add a note to my above post.
I wonder if D1 would work just as well… :slight_smile:
Oh wow just 3 or 4 days ago nearly 1000 pieces were in stock.
Pop your multimeter in continuity mode and give it a try!
It appears the 5-pin variant (if it is actually a variant. The datasheet doesn't show any other footprint) will work with XP boards.
Now to hope they are of a decent bin. Will try to attempt to measure that tonight. Never have tried to before.
That’s what I was thinking of doing next we will see how it goes
Thanks ImA4Wheelr
I noticed both footprints are the same.
I will buy 3 to testout :slight_smile:
You may want to hold off on that order. I'm getting lousy measurements. Higher Vf's and lower calculated lumens then both djozz and koef3 reported. Please keep in mind that my lumen calculation could be way off as I haven't really spent much time working on my integrating tube and have never measured a bare emitter. I hobbled a set up just a bit ago. So there is all kinds of potential for errors. Conversion factor derived from maukka calibration lights.
Current Vf Lux Lumens
1
3.14
364 245
2 3.49 617 415
3 3.78
814
547
4 4.04 955 642
5 4.31 1040 699
EDIT: Improved the setup up. I was losing lumens around the heatsink. I resolved that a good bit, but am still losing some lumens. My new measurements are as follows:
1
3.14
445 305
2 3.49 763 523
3 3.78
1009
692
4 4.04 1186 813
5 4.31 1290 885
That Vf seems way too high for this LED at max brightness.
I definitely was a bit disappointed in the Vf results. The reading seems reasonable according to the bins listed in the datasheet. Used a DPS5015 to provide power and to measure Vf. Used about one foot of 18 gauge leads. Didn't see signs of thermal sag.
I will remeasure tonight with a meter directly on the emitter.
That explains it partly. Your meter will probably measure lower values.
You weren't kidding. I was expecting a small difference, but was surprised. I verified power supply readings at the power supply terminals, no problem. Then measured at the emitter pads. I read 3.02, 3.23, 3.42, 3.60 , and 3.80 volts at 1 through 5 amps, respectively. Good news from an emitter efficiency standpoint. Thank you for sharing your observation The_Driver.
Those values are realistic. The LED is probably brightest at 4-4.7A.?
Thats great! who can make a distance ring for black flat?
The GT mini also has same body setup like D1S. 5 black flats ordered last week and I will put one in aa GT mini, one in a Convoy L2 on led4power MCPCB. And maybe one in a modded Convoy S8 to see what throw I can get from a small tube light.
On C8 you can get up to 300kcd with 1000% perfect focus and a “good” Black Flat .
