Is the CDR number indicate discharge rate at all time, like until the battery is nearly depleted or it’s just the average rate? I like to be able to hit turbo even with low battery if that’s possible. I also hear with enough current you can boost the brightness off the chart up to nearly 7000lm, that i’m a bit ambitious with.
On the side note: Are there any way for the user to calibrate the temperature sensor of the light? It kinda pointless having a thermometter that isn’t accurate isn’t it?
On these lights “turbo” is just “as much as the battery can supply to the LED” - you will always be able to get to turbo but it will drop in brightness relative to your battery voltage/current for the entire time you have it on. So turbo at 25% battery will be quite a bit less than turbo @ 100% battery. There are more advanced lights and boost drivers that will give a more constant current despite battery level but they are quite a bit more expensive (ex: Noctigon Meteor M43)
It isnt pointless to have to temperature set wrong. Depending on the firmware some will allow you to set the step down in two ways:
1) in config mode there is a way to get it to go in Turbo and you hold it there until you think the light should step down. It sets the ceiling. This is a relative temperature and as long as it’s consistent it’s very much still worth it.
2) Some of ToyKeeper’s newer firmware will let you program in the ambient temperature and then you choose a step down based on a temperature value you choose
Turbo is not a specific number of lumens; it is direct drive. Brightness is determined by where the LED’s forward voltage curve meets the battery’s discharge curve. And, at only 2.9V, it won’t be very bright no matter what kind of battery is used. That is an empty battery pushing less voltage than the emitter wants.
According to Texas_Ace’s testing, it would max out at less than 230 lumens per emitter at 2.9V, even if the battery was capable of pushing a thousand Amps.
This is the answer i’m looking for, thanks a bunch.
Don’t know why i keep saying turbo, it’s a habbit i guess. But yeah, i was wondering the emitting capable of the LED at low U and high I
BLF Q8 with NarsilM v1.0 (or v1.2) doesn’t have thermal calibration feature.
Let’s say the stock BLF Q8 (or other NarsilM flashlight for that matter) is very wrong (eg. ambient is 25 deg C, but “thermal check” reads 45 deg C)
Say I flash it to Anduril, then I calibrate the temperature there (25 deg C more or less is 25 deg C)
When I flash the Q8 back to NarsilM (say v1.2), will the thermal sensor (which was previously calibrated when it had Anduril) be back to the earlier wrong reading, or will it become correct (the value configured in Anduril), or just some other random thermal value?
HKJ and Mooch both put constant loads on the batteries starting at 4.2v and ending at 2.8v and discharge it at multiple rates. To get a continuous rating the cell has to stay within a “safe” temperature range. I think this is below 80°C.
It can be a bit off. It just means the light might thermally stepdown too early or too late. Usually the factory setting is pretty close. You can customize the step down temp to whatever you want or switch to a timed stepdown.
When setting the thermal step down temperature yourself, the light will turn on to turbo and then you just hold the light until you think it’s hot enough and then click the button. So you don’t actually have to know an exact temperature number to set it. Whatever temperature number it read when you set the limit is when it will step down in the future.
The temperature sensor is built into the MCU chip and you can’t really get super accurate reading from this style of sensor compared to an externally mounted sensor. It still works fine, though. You don’t even have to have a thermal step down if you don’t want it. You can turn it off and then control the temperature manually like most lights.
I believe the way Anduril calibrates it’s sensor is to just adjust using a correction factor meaning it adds or subtracts a certain amount from its reading. So if the light is actually 25°C and it’s thermometer says 45°C (the tolerance would not be that high, maybe plus or minus 10°C is more accurate) then you would tell it to subtract 20° from all its temp readings. Now it’s “accurate”.
If you flash to NarsilM, that correction factor disappears along with all the Anduril code. So it should be back to reading 45°C.
As it was said earlier, the MCU does not really need to know the accurate temperature. It just needs to know the relative temperature so that it can activate the thermal step down.
I’m not sure why ToyKeeper added a temperature calibration circuit, since it’s technically not needed. Maybe there’s something specific to Anduril that needs to know the actual temperature?
Because you click however many degrees above 30C you want it to step down at. 60C = click 30 times. So now you have a calibrated temp and a more precise step down setting.
Is this in reference to me asking why Toykeeper added the temperature calibration?
Why do you need precision? My hands tell me when it is hot enough. The thermal step-downs main purpose is just to prevent you from burning your hands. Eh, no big deal.
Why not? Why do people like Android phones over Apple and vice versa? With a value I can (easily) tweak it a little higher or lower as I wish. They both get the job done.
I like the simplicity of hold-until-hot, but in this case I went for something a little more complicated in order to get better results.
Running a light in turbo until it feels hot enough… is kind of obnoxious and imprecise and not feasible at a factory… especially on bigger lights where it takes a long time to heat up.
The calibration function makes it much easier to get consistent behavior on each light. In theory, the company making or selling it could calibrate each unit in about 30 to 45 seconds, and avoid a lot of issues with products overheating.
If it’s not factory-calibrated though, it’s still reasonably simple for a user to do it, and faster than the hold-until-hot method. Go to thermal config mode, click enough times to tell it the current temperature, then wait a few seconds for it to fall out and go back to its previous state.
Anyway, hopefully the factory or vendor will do it so the user doesn’t have to.
I don’t know, but I hope so. I recommend it, repeatedly, to everyone who sells lights with Anduril (or RampingIOS V3, which also supports calibration). It improves things for users, and should reduce return rates for vendors, by preventing common issues.
Actually it off ALOT. When i temp checked it read 42 Celcius but room temp was 20+! And ofcourse the light was not being used. I use the time stepdown setting wich reduce turbo after 7 mins. However i like to play with the temp check, it just that i like to use it that’s all, to me it’s not a big deal anyway but having it off too much make me itchy.
I have 3 lights with NarsilM. At 23°C room temp I got, 19°, 21° and 22°. You certainly have a large deviation. Are the lights internals at room temp? Any time you use the light it gets warm internally and you have to wait maybe an hour or more for it to fully cool down even though the exterior may already be cool.
It’s very easy to set your own temp stepdown if you want to switch from timed. I did a video on just this procedure.
