New fenix E16, only 51 mm and automobile ultraflat lens
They haven’t been released yet. Fenix Stores says not until end of Sept, beginning of Oct.
Fenixlighting Store says “Due to high demand, this product’s initial inventory is sold out. The next available inventory won’t be available until Mid-October.”
So they sold out of the first run they had.
Unless they run some kind of coupon code or GB (a deal I just can’t refuse), I think I still prefer the Olight.
Thats Fenixlighting. FenixStore, says release date is Sept. 28th and is still taking pre-orders. I haven’t heard anyone getting one, and don’t think theres been a first run released yet. Fenixlighting may have sold out their pre-sale Sept. allocation.
If you want Nichia in this form factor, Klarus released a version of the Mi1C with the 219C a little while ago. Klarus’ UI isn’t as good as Olight’s, but it is definitely less bad than Fenix’s, IMO. Klarus uses a single click for on, long press for off, double click for strobe. I’m not a fan of long press for off, but I can tolerate it. Long press for on, though, just… no. Especially when Fenix uses a slightly-longer-press for strobe. That’s just a recipe for accidentally strobing yourself.
Interesting design but the UI is awkward.
Who though that long press for ON would be a good idea? Also, OFF is 0.7 seconds away from Strobe…
Even the demonstrator in that video, seemed he was having a hard time not going to strobe
Wow! I had no idea, that sounds like an improvement over the Low CRI options… I would have wanted that IF it was the Aspheric version. The reflector versions of the Klarus have a tiny hotspot and large spill, that I dont like for my indoor use. In fact, Im expecting an Aspheric Klarus in the mail today.
I like that the Klarus Mi1c and Olight S1 Mini, and Utorch S1 Mini, include a USB rechargeable 16340…
the Fenix does not include a battery, it costs $8 extra, so when comparing prices, the Fenix costs $48 w battery, and the Olight S1Mini costs just $2 more. (I dont recommend the Fenix USB rechargeable, it is longer than the Olight version.)
probably an attempt to reduce Accidental Turn On :wink:
Some months ago:
Very nice and small torch and the button and bezel hopefully made of solid copper. But always these Clip-on Pocket Clips I hate these things, there are so many other ways to attach a clip to a flashlight……the emphasis is on “attach”!
I think it is colored stainless:
Too bad and then the clipped clip, this flashlight is unfortunately nothing for me. Then I prefer to stay with my SMini or my Klarus MI1C CU, it has at least a reasonable clip :+1:
yes, the Fenix has its own pros and cons, and the Klarus has its own advantages and disadvantages also
for example, the optics are completely different, the Fenix is a TIR with a wide hotspot and almost no spill, while the Klarus has a tiny hotspot and a large spill from a reflector.
Klarus also offers an Aspheric option that neither Olight nor Fenix offer.
Klarus and Olight offer High CRI models
Fenix and Olight offer Neutral White, but Fenix has No High CRI
The Klarus UI is different than the Fenix… imo Klarus has the advantage here, its UI is closer to my favorite, the Olight UI
The Klarus includes a battery and charging cable, Fenix not.
between a 219c Klarus, and a NW Fenix, I think the Klarus might be the winner overall
The 219c Klarus costs the same as the Fenix
the Klarus is 4gm heavier and 4mm longer than the Fenix.
Max on Klarus is 395 lumens High CRI, vs 700 lumens Low CRI on the Fenix
I wish I had known there was a 219c Klarus, when I ordered a regular cool white Aspheric model a couple of weeks ago… darn!
anyway… I wonder if the Aspheric would work on the 219c model :slight_smile:
Wait…. Long press to turn on/off/strobe?? Pass on this one
- Clemence
A quick size comparison. Barely larger than the Atom AL mule/aspheric and smaller than a traditional TIR.
I was intrigued by the Fenix E16’s optic.
The beam pattern is primarily thowy like a tradional OP reflector with a central hotspot and secondary spill. But as a result of the shallow emitter placement, there is also a wider tertiary spill (160+deg.); this actually works well for close-up illumination. I can see more lights experimenting with this lens.
(Fenix E16 on left, Atom Mult/Aspheric on right)
By Fenix Store:
Very interesting, thanks!
Congrats on your new Light!
thanks for the comments on beam shape and close range usefulness
really appreciate your photos!
could you share a 3 light beamshot please :slight_smile:
On left your very pretty Neutral White Ti S Mini,
In the middle, the elegantly diminutive Fenix E16,
and on the right your super cool Aspheric Atom
What are some of your thoughts on the Fenix Tint?
photo staging suggesion:
left to right on folded white printer paper: (warmest to coolest)
example
l-r 4000k N219b, Neutral White Ti S Mini, Cool White Novatac
That is iPhone pic, auto white balance, taken during the day, equivalent to daylight white balance.
Hmm, interesting beam… looks pretty throwy for such a small light. Me like! :slight_smile:
Hi Jon_Slider, here ’ya go.
From left to right -
Fenix E16 Neutral Warm XP-L - Olight S-mini Ti Neutral XM-L2 - 47’s Atom AL Aspheric Neutral 219C
(The E16 is very reflector like.)
@Lightbringer, the little munchkin out throws some larger bezel lights I have. But bear in mind that -
# on Turbo (w/16340) it gets hot fast (20-30 sec) which means it’s conducting well but there’s simply not enough mass to carry the heat away. High using a 16340 or Turbo using a CR123a is a more practical level, and
  1. the UI is Hold to turn ON/OFF (not my first preference) and as a result there’s no Long-hold or other direct access to Low/Moonlight. Long-hold goes to Strobe and Double-click goes to Lock-out.
Otherwise it’s a real pocket rocket.
Not worried about 1, but yeah, 2 might be a concern.
I don’t mind longpress for on/off, but would use more clicks like the SP10. Eg, 2click for highest, 3click for irritating strobe, 4click for lockout.
I’ve gotten used to direct-access to moonlight/firefly, but… nah, was gonna say I could do without it. Maybe in a bigger light, but in a smaller light with frequent-use, I do use ml/ff quite often, so…
