*BLF LT1 Lantern Project) (updated Nov,17,2020)
If it can already take batteries that are 71mm long and 18,9mm wide, would it be possible to make it a little wider so that everybody who needs maximum runtime could also use 20700 or even better 21700 batteries?
Yeah battery carrier sucks! :open_mouth:
Hi, great project, can I please be put on the interest list for 3 to 5 depending on the price.
Thanks
I’m interested for one depending on the final pricing. :slight_smile:
Thank you
Could you put me down for three lanterns on the interest list? Thanks!
OK. My views on everything.
There should be a substantial stainless steel connection for a three leg stand. The hole for the tripod must have a complete water barrier internally. With no possibility of being penetrated/destroyed by a long attachment screw. Is making a tripod for the lantern being considered? The Q8 version of the bottom cap may not be strong enough for holding a small tripod in a center hole. The lantern will be tipped over, and worse. This is a potential weak point. If making a tripod, be sure you look at the leg spread required to minimize tipping the vertical mass, and uneven surfaces.
Flats bad; knurled good. No apparent reason to have flats except possibly around the control button.
Sloped plastic surround; maybe not so good. It could be done with a standard piece of plastic tubing; lower cost. Perhaps more durable/scratch resistant than the current selection. Top heat sink could possibly get smaller diameter but thicker heat sink/more fins if needed. The overall heat management needs to consider a range of environmental conditions. Is it zero F or 100 F? Both could be possible. Straight tubing would make it simpler to apply a removable shield to mask some areas of light. Much easier to find a replacement in case of damage.
Battery carriers have some significant merit. No carriers and extension tubes are one of the few things I did not like in my Q8s. First, the newer battery formats need to be accommodated. I have seen little preparation for new formats. Preferably using inserts in the carriers for the 18650s. In a year or two, we will be saying “Why on earth did we not consider the new battery formats that are replacing 18650s”. The carriers with extension tubes could double or triple the run time of the lamp even with just 18650s. I bought a TK75 for this feature. At bedside it has a 1 segment tube. In the closet is a tube for 3 carriers with charged batteries sitting with the tube. The sizing for the tripod would need to be designed to control tipping with a new center of gravity.
I do not believe it is reasonable to include external charging, charging phones, or jump starting your SUV. Anything not directly connected to it being a lantern. There should be a thoroughly sealed control button penetrating the shell; no additional holes in the shell using “stick in” sealing (none when doing external functions in the rain). I have multiple devices (phones, radios, etc.) where these little rubber plugs have shown their inability to work over time, or still be attached after some use (and just normal infrequent use). I think most people will use these lights in two ways. Emergency lighting; camping. I do not see many people wandering around holding up a lantern rather than a flashlight.
Using/charging the batteries in the lamp should not be a feature. There are many many inexpensive and compact external battery packs to charge your phones. Not to mention your vehicle. Why suck run time from the lantern. IT IS A LANTERN. Not a source of getting power to watch a program you just can’t miss.
If we absolutely need to have these, I would want the type C connectors. It is where we are going. Using another version of USB or other protocols is just stupid. For a few dollars you can get a cable for the type C. There is no reasonable way you can fix the lantern if it is not type C. It boils down to type C now with an adapter (if needed), or adapters for all your nice new stuff.
Efficiency of the lamp should be the number one electronic priority. Whatever electronics are used; this should be the absolute guiding objective. IT IS A LAMP.
I do not view radiation frequency variations as a useful addition. I can live with it, if it does not reduce run time or increase cost. Otherwise, over a rather long time, I have been exposed to all of the visible spectrum (think walking outside on a sunny day). Some bands in the visible spectrum I like more than others. But I JUST DON’T CARE IN A PORTABLE LANTERN. If there is no cost or loss of lighting efficiency for variable spectrum; OK. Otherwise no; IT IS A LANTERN.
Probably best if you don’t buy this lantern.
I’m glad we got that resolved. :slight_smile:
I am reasonably sure this is meant to be a lantern not a lamp
Definitely agree, This project is probably not for alternety if all those views are expected to be in place or changed to please one person.
As we told one other before, were not going to try to please everyone, nor will we never be able to please everyone. The goal here originally was to design, build and have a lantern available that has a good balance of features, usability, off-grid sustainability, & versatility while keeping the retail cost down as much as possible in comparison to other commercially available lanterns in the size range. Once this one is rolling into production, we may look into building a simple “base model” of this same lantern for the cost-conscious buyer with no charging, tint ramping, etc. I should mention though it is a “lantern” & not a lamp, I had to giggle a bit at the number of times it was called a lamp in one reply.
I like it enough as it has evolved that I still want the two I put my name in for way back. And yes, I want a lantern. :wink:
I think a Base Model would be a great seller, nice idea.
Start a list :slight_smile:
Let’s complete this project before starting any spinoff lists. Too much to keep track of as it is.
agreed.
I agree with the middle section, keep it as compact as possible
The driver in its current parts has just 3mm parts height, so there can be a cavity of like 7mm max height to easily fit all the wires
so no battery carrier as its 4P
in the middle section my advise would be placing the USB in and out ports
and the switch placed on the top of the lantern, or better both top and side
agreed I would manufacture the battery tube from one piece, no hassle with drop damaged threads of the relative fragile Q8 tail cap
or do it massive to support more stability when placed on a table with like 3-4mm more diameter
I would simply make a hole in the battery PCB on the tail to allow the Tripod mount stick into it so we can get it 2 maybe 3mm shorter
If Barry can have the engineers make the battery tube as one piece with the bottom cap to make it shorter & simpler then i am good with that, as long as it don’t cost more as they already have a current template for the battery tube from the Q8, (though the lantern has a re-designed cap that is a bit thicker to allow the bottom tripod mount to be more solid) but if Barry indicates that it wont cost more to make a new one piece battery body then good. (I am guessing they would have to make a new bottom PCB with springs and mount inside from the inside correct in that case)
If the driver only needs that amount of space then i can do a quick edit of the images Barry sent me with a little more of the mid-section removed to make it shorter to send him. ( i can ask him about the ideo of a one-piece bottom & tube too.
Maybe you missed my last comment, but what do you think about making the battery tube a little bit wider, so that you could also use 20700/21700 batteries if you want maximum runtime? At the moment it looks like the battery compartment is the smallest (least diameter) part of the lantern, so that this wouldn’t make it significantly larger.
That look much better :+1:
The image shortening looks good. :slight_smile:
I agree the mid section can be shortened like that in your edited pic of the cross section, but the switch can not go in that location in the center of the top as that is the bolt location that holds the top end down in place. (and i have never liked any of the lanterns that i had/have that have a top switch for many reasons, (one being the Zanflare T1) and the plan is to have the glowing switch boot like the Q8 as a night light/firefly glow (but in amber instead of green)
Even with the shortened midsection there should be enough room for the electronic switch on the side 45 degrees around from the charge port.
I believe that opinionated design meant to suit a subset of users well rather than to more-or-less-please-everyone is just right.
Nevertheless in this context I really dislike the name. This is not any kind of ultimate light.
