Interested
[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
Interested!
Interested, hopefully it’ll be cheaper than the ROT66.
What a great practical advice!
Thank you FireFlies
I use a H03 as my winter EDC and I don’t carry the headband with me.
When I need a hands free light for few minutes I clip it in front of my collar. That is mostly enough with a floddy light although it is looking down.
I like the way that clip drawing looks. Make the light truly practical and it’s sure to appeal to a lot more people.
Interested
Or a Manker style clip.
ToyKeeper: Tally-ho:I’m fed up with this pocket-clip-catching-in-its-wrong-spot the pocket because the bent part is too short.
When you pull the flashlight down in your pocket, the edge of the pocket is going right here :
Instead of here, if it has a longer bent part (in red) :
Or, even better, use an Olight-style clip which doesn’t have that problem:
Problem with the Manker style is it will leave a weird edge of you remove it. It’s also more expensive to make.
Interested. I will follow the thread carefully, then I will decide
Thank you FireFlies
Like this, so the flashlight is actually inside your pocket instead of dangling outside.
I’m down with the Skilhunt clip. :+1:
I’m happy as long as the clip remains removable and it doesn’t add any weird bumps like the Manker one does.
Interested. Hoping for a 4000k or warmer color temperature option.
leroycp:“even better, use an Olight-style clip which doesn’t have that problem”
Ditto. Olight clips are very well designed, I wish I could buy them separately.
I have contacted Olight in the past and ordered just the clips. About $5 a piece if I remember correctly. Didn’t find them on their site so I just emailed them and they took my info and shipped them. Might try that if you know which ones you want. This was a while back so not sure if they still do that.
Possibly, pending price
Available soon. [quote=Sillen] Possibly, pending price [/quote]
In!!
Interested, but which is a price point?
Lower than ROT66 for sure.
